Question about Homelite Ut80993 Honda Gas Pressure Washer
Looses pressure - Homelite Ut80993 Honda Gas Pressure Washer
Davey pump loosing pressure from rain water tank to house but seems to be fine through the day but loosing pressure at night?
replace the pressure control switch as the problem indicates the non-return valve is leaking back and not holding pressure
Dec 10, 2016 | Plumbing
Is the regulator button supposed to be loose on the technique 6.5 oval pressure cooker
Yes, it is a weight and it is intentionally loose to ensure that it can release pressure in case of an emergency.
Oct 16, 2016 | Home
After initial surge at full pressure, pressure drops to hose pressure
loose impeller or broken part inside casing, the pressure relies on the casting being made to have a very close tolerence with the impellers movement. if a wall inside the casting is broken away from the original position that it has to be in order to create the pressure constantly. or the impeller could have lost its key or the nut that holds in place came loose and it spins but not enough to maintain any real pressure.
Oct 29, 2014 | Garden
Replaced oil sending unit, still loosing oil pressure
the oil pressure sensor connector may be the problem.unplug the connector and see if there is a gray sleeve on the end if it is missing you will need to replace the connector
Feb 17, 2014 | Chevrolet S 10 Cars & Trucks
Pressure regulator knob broken
Do you think the knob is broken because it is loose? It should be loose and move easily over the valve. If it is really broken, you should contact the customer service of the home shopping channel where you purchased it.
Feb 06, 2014 | Cook's Essentials CooksEssentials 3 Quart...
F-250 diesels blowing white smoak? Why?
More than likely your loosing fuel pressure, you may need a new under hood fuel filter and the low pressure pump located on the frame rail on the driver side of the truck. The ICP sensor (Injector Control Pressure Switch) could also be bad and cause this. But normally if your blowing white smoak and your loosing power at the same time I would say fuel pressure. But if your not loosing power and just have white smoak I say ICP sensor. Also check your engine oil, if its low or extremely dirty, this can cause this also. It uses the oil pressure to run the ICP sensor to control the injectors.
Jul 22, 2011 | 2005 Ford F 250 Super Duty
Loss of power, stalling at stops and slows, codes P0300, P0107, P0105 and P0105. Will stall but when put into nuetral will start right up.
The symptoms and the codes you've given would indicate to me that you have a vacuum leak. Look for a loose a throttle body, loose, missing or damaged hoses, loose or missing intake manifold bolts or any other opening in the intake manifold.
P0105 - Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0107 - Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0300 - Random/Multiple Cylinder Misfire Detected
Jun 17, 2010 | 2001 Pontiac Grand Am SE
Loose oil pressure at idel then picks back
HI, SOUNDS LIKE YOU OIL PUMP IS GIVING UP OR YOUR FILTER COULD BE DIRTY, I SUGGEST YOU REPLACE IT BEFORE YOU MIGHT GET STRANDED AND COULD POSSIBLY HARM THE ENGINE... HOPE IT HELPS MARCOS..
Mar 24, 2010 | 2004 Ford F150
Oil light on when oil is full
a loose connection WILL NOT cause flickering oil light unless your your oil is empty at the same time a connector is loose. This flickering is most likely caused by clogged oil ports or failing oil pump. When this happens there is insufficient oil running through the engine, causing the sensor to activate the light intermittedly. Have this checked immediately to prevent extensive engine damage. Hopefully this helps!!
Mar 20, 2010 | 1998 Toyota Camry
Air Condition
it sounds like a loose compression compressor.
if the compressor is loose compression, normally it sounds noisy. then suction pressure is above normal and if you accelerate and maintains that high speed, let say 2000 rpm, the suction pressure goes down to the normal level and cools your air conditioning .
tnx 4 using fixya...
drcool
Aug 29, 2008 | 2004 Nissan XTerra
Homelite Ut80993 Honda Gas Pressure Washer Logo
26 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
