Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
Can you adjust throttle on rascal scooter R245. It is loose
2 Suggested Answers
gopakumarg43
  • 75311 Answers
SOURCE: Rascal 240 scooter Battery charged ,scooter
Hello
There is an overload protection switch in it. It will look like the the protection switch that can be seen under the mixes. The picture of the overload protector is added here. Its press button will only seen outside. Just putsh it once and check. The motor has carbon brushes inside it to get armeture contact. If these burshes are worn out, the motor won't turn, and the scooter won't move. There will be two of them in opposite directions. They are replacable parts. The picture of it is also given here. Check these first. If you need anymore assistance from me, feel free to get me by FixYa.
gopakumarg43.gifgopakumarg43_0.gif\
OK
Posted on Aug 05, 2011
Rascal Candy Apple. Why did it stop moving while I was driving it?
On the rascal, if your driving along and it suddenly stops, the throttle lever could be bad or the speed control could be bad or both. A battery lead maybe loose. The tiller cable may have slid back causing line interruption.
The flashing 4 indicates current timeout, the scooter may have been going up a steep hill, over heating the motor, turn off and allow motor to cool. then try again. if this happens on flat ground then check the parking brake, it maybe hanging up causing the motor to over work. Other trouble-shooting information for rascal, scooters on my free app.
Scooter Doctor App
Aug 11, 2015 | Health & Beauty
I replaced the speed pot and throttle pot now my rascal 235 drives but only about half speed
Sounds like one of them has incorrect values. You need to check the resistance marked on the original speed and throttle pots, with the new ones. Generally a throttle pot is 5Kohms and 20 or 200 ohms for the speed pot.
Oct 15, 2014 | Health & Beauty
I have a Rascal 200..was working fine..now after you go forward and let go of the throttle. ..it goes in reverse itself. .is there a throttle adjustment?
I had a similar problem on my Pride Legend scooter, it would
creep back in reverse if you let go of the throttle. The FWD/REV spring tensioned throttle pot inside was "off center"causing it to activate in reverse when it should have stayed put with the electric brake energized.
I had to replace the throttle pot assembly. Not sure if yours
is similar, but I would suspect it might be.
Jul 29, 2014 | Electric Mobility Rascal Scooters,...
Rascal scooter
Could have a wiring issue you should look in the console make sure nothing is crossed.
Jul 21, 2014 | Electric Mobility Rascal Scooters,...
No power output from Rascal 600f from controller
Put a meter on the Connection to the motor, try to engage the throttle see if any DC voltage is being given. if so does the voltage go up and down?
Apr 14, 2014 | Electric Mobility Mobility Electric Power...
Rascal Scooter model 245
If the throttle is stuck a little bit then it may not let you start it while the throttle is on
Apr 13, 2014 | Health & Beauty
Rascal scooter
Could be the Throttle Pot or Speed Pot. The levers will change the resistance of the throttle pot. The speed pot feeds the throttle pot.
Move the speed pot while pushing the lever forward. If it works could be the speed pot has a dead spot on it. Also check wires loose and a mechanical issue with the throttle pot and the springs.
Apr 04, 2014 | Health & Beauty
How to make rascal 600 scooter fsater 5 mp.
in order to get it to go faster, you could put larger wheels on it, or get an OEM programmer to adjust the speed. They did not want to be sued so they did not make them available. any of the higher speed scooters have hand brakes. There probably is a market to sell ways to speed up Rascals, but I can not except the liability. sorry Scooter Doctor App
Feb 12, 2013 | Electric Mobility Rascal Scooter...
I have a 245 Rascal Scooter. I need to know if I can lower the seat?
most rascal 235 and 245 scooters come equiped with power seat height control. you turn the key to the left and then the throttle lever becomes the seat height controller. the seat motor is ditectly uuder front of seat post. if it will not run follow wires to see that they are plugged up good.
Jun 09, 2010 | Golden Technologies Golden CompanioN II -...
Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Feb 24, 2010 | Health & Beauty
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
22 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
