Question about FreeMotion 350R Recumbent Bike
Where do i plug in the bike - FreeMotion 350R Recumbent Bike
Where does the h35HR exercise bike plug in?
Plug the power adapter into the receptacle on the frame of the exercise bike.
The insert for the power supply should be toward the bottom front of your machine.
If any other issues, please do not hesitate to call us at 888-713-2880 or visit us online at www.sportsmith.net
May 02, 2015 | Exercise & Fitness
I moved,so I took the bike apart.can't find a plug or wire to plug it in
you have to buy an adapter the plugin is behind the right side battery panel if you're sitting on the bike
Mar 19, 2014 | Golds Gym Cycle Trainer 390 R Recumbent...
Spark plug fails after two hours of riding??
Either you got the wrong type plugs (too cold) and/or that bike is running way too rich! Time to use a tool like ColorTune to get to the bottom of it. Who normally works on this bike? If you don't do the work yourself, then better to take it to a reputable shop/mechanic.
Mar 18, 2014 | 2005 KTM EXC 125
Theres no spark and bike wont start
you will have to check lead to spark plug then lead to coil
if your not getting spark at plug it could be a number of things ingintion
or just a loose wire best of luck hope you solve it
Mar 15, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
How to change gearbox and engine oil
There is a sump plug located at the bottom of the engine. It is very tight. Make sure you have the correct size socket to remove the plug. Use a suitable oil pan under the bike before removing the plug. Once the plug is removed and the oil is drained, stand the bike upright to get the last of the oil out. Get the correct oil, about 1 litre, replace the plug and fill the bike to the correct level using a funnel. Stand the bike upright to check oil level. Do not screw oil dip stick in to test the level.
Nov 02, 2013 | 2008 Yamaha YZF-R125
Which drain plug is for oil on the engine, right or left?
Underneath is the usual location for sump plug. Otherwise sitting on the bike the oil drain plug should be on your left side underneath the front sprocket somewhere....
Feb 23, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
Have a c50, i turn key to on position and flip power switch on. fuel system begins to power up and then stops mid way through the cycle. starter will work but bike will not start.
U check the bike sparks plugs distributors caps and those sparks plugs itself for of the bike for dirtyness and dirts by tries cleanning it with some DW40 chemicals spray for better contact for fuel ignition burn?Yes,than check all of the sparks sets firering gaps in the bike are dull and colors of those sparks plugs are blues or old blues colors in the firering gaps.The sparks plugs set in ur bike are 3 or 4 years old?Yes?Change the bike for another set of spark plugs.
Oct 02, 2011 | 2005 Suzuki Boulevard C50
I changed plugs oil fuel filter engine turns over but won't start. Are plugs pre set or do I need to take them back out and gauge them?
plugs are normally preset,not sure of your bike but sounds like you may have put plug caps on wrong plugs and firing order is now wrong. if its a 4 cyclinder bike , 1-4 fire together as does 2-3 . # 1 IS L/H SIDE OF BIKE SITTING ON IT
Jun 23, 2010 | Motorcycles
2001 yz 426 spark plug
Remove plug then reinsert top cap only let plug hang free now kick over starter wile somone watches the plug for spark (the darker the better!)
Dec 17, 2008 | 2001 Yamaha YZ 426 F
FreeMotion 350R Recumbent Bike Logo
61 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
