Question about Xerox 6505/n Workcenter 6505n Color Laser Mfp, Print/copy/scan/faxemail, Up To
I have a brand new workcentre 6505dn color multifunction printer. I have been getting these four color lines from the top to the bottom of my pages. It only occurs when I copy or scan. I googled and found that a lot of people have had this problem. I have tried to fix according to answers on line. I have changed the ink cartridge on the side. I have cleaned the glass. Nothing still works... if anything the lines seem to appear brighter. Can someone give me some pointers on what else I could do to fix this. Thank you in advance :)
SOURCE: my Xerox Documate 510 adds
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Posted on Mar 05, 2009
SOURCE: Was working fine I scanned a lot of documents.Then
how can we download this driver
Posted on May 01, 2009
Arius
  • 446 Answers
SOURCE: Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Posted on Jul 28, 2009
FixinFax
  • 3085 Answers
SOURCE: I am having problems with my Doucmate trying to
If you pull open the front cover open you will see that the feed switch is probably stuck in the down position and not springing back up after each oage.
Posted on Jan 14, 2010
  • 239 Answers
SOURCE: My Xerox Workcentre is not printing out very dark
If the copies are coming out with a school fence type image on the copy, it sounds like the low voltage power supply is causing the problem.
One other area to know about is, the laser head might have very dirty mirrors. The mirrors get a film of dirty haze on them causing the copies to print out very faint.
The repair is very involved and complicated.
In order to clean them, the laser assay would need to be removed and opend up. Very delicute care need to be taken when preforming this task.
Another area is if the copies are coming out light, suspect the software version is not up todate. A serivce call might have to be made on it. The service person can update the software on the machine.
Good luck and be safe.
Posted on Aug 23, 2010
WHAT IS THE NVM RESET FUSER CODE FOR THE XEROX 7545 COPIER\
Have a look at the following link:
http://www.enxmag.com/2013_months/aug2013/WorkCentre7425StyleFaultCodeList_82013.htm
It has a list of fault codes and also tells you how to reset NVM counts. Look in the bottom right of the page for the instructions. Hope this helps.
Jul 16, 2014 | Xerox Workcentre 7545/P 7545P Color...
Xerox workcentre 3325: What do you do when you are having lines on copies when using the top feed?
NO NO NO.
Don't rush things. If you don't know how a laser printer functions, please don't touch anything. Let someone with knowledge clean the machine. Rubbing the wrong roller, can damage the printer bend repair.
Only clean the parts you are allowed to clean. Like removing dust on places outside the printing area.
Jul 15, 2014 | Xerox WorkCentre 3325/DNI - multifunction...
Scan documents on the 6505/DN using my pc or mac, what do I need from xerox
copier/scanner should do the trick and the new product will contain all the equipment.
Oct 17, 2013 | XEROX - COLOR PRINTERS 6505DN 6505/DN...
Xerox 7132 printing dots after 35 pages
Check if it is with just one document or with all documents. Can also be coming from the job and not the printer
Apr 07, 2013 | Xerox WorkCentre 7132 Multifunction Color...
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
Xerox 6505/n Workcenter 6505n Color Laser Mfp, Print/copy/scan/faxemail, Up To Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
