Question about Dryers
Am i aloud to put my dryer on top ov my washer
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Acceptable. Think safety to avoid slippage of toe dryer on top of the washer. A rubber base on top of the washer will be a good start.
Posted on Oct 17, 2013
Whirlpool duet dryer making aloud thumping noise when running?
Have you opened it or you looking for someone to guess what it could be?
Nov 18, 2014 | Whirlpool Duet WFW9400VE Front Load Washer...
Can a front load washer be stacked on top of a front load dryer?
Normally, the front loading machines come with a special stacking kit (that may be available separately). Now I wonder why one would put the washer on top! Most of the time the washer is put at the bottom making it easier for plumbing. Secondly, in case of a large spill, it would be safer to have the dryer on top due to the power required for the heating elements. I would therefore not recommend putting the washer on top even if that might be possible to do so...
Oct 24, 2013 | Whirlpool Washing Machines
It making aloud noise when spinning dry
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washer wont aloud my water to go insidethe washer
If the washer makes a humming sound, but no water goes in, and there is no other action, the water shut-off valve is off (outside the washer), or the pipes are frozen.
For top-load washers: If the washer starts agitating immediately without filling the tub, the water level switch is bad (falsely senses the tub is full already) or the water level sensing hose plugged up while there was water in the machine, and it has still has pressure inside it to fool the level switch.
Nov 27, 2010 | Maytag Washing Machines
How do I put the top cover of the washer back? I had the dryer put on top of the washer when it was first installed and took the washer cover off so the dryer can be bolted and sit on top of the washer...
Lay the panel on top of the washer with the screw holes pointed towards the back. Slide the panel forward until it is flush with the control panel. Reinsert the screws in the rear to secure.
NOTE: There should be a couple of tabs near the control panel on most of these washers that the top panel slides into to lock in place.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this help you.
Jul 04, 2010 | Kenmore HE2 Plus Front Load Washer
My washer makes aloud noise when on the spin cycle. HELP I Started a load of laundry and it washed fine until the spin cycle. It started making a terrible noise.
sounds like the bearings have worn out at the back,to check this open door and with your hand lift chrome inner drum up and down if you feel like a knocking noise then its bearings,
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Stacking the washer and dryer
Been a while since I did one, but as I recall: Two side pieces secure to top of washer with peel off tape and a screw into the top at the very back of the washer's top. Dryer sets on top of washer with back legs sliding into the stack kit side parts. Front rail holds front dryer legs, secured by one screw on each side into stack kit side pieces after dryer is set on top of washer.
Nov 09, 2008 | LG WM-2277HW Front Load Washer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Stacking Frigidaire dryer on washer using stacking kit 5303937141
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
