Question about Hobart Food Mixers
How many liters of oil? - Hobart Food Mixers
  • 2,113 Answers
In Hobart Mixers there is supposed to be a glass portal to verify that the gear oil level is proper. There are so many Hobart models it is difficult to have an exact figure for how many liters it needs. I remember buying gear oil for a Hobart and i don't recall if i purchased it from a restaurant supply or somewhere else. But i think any gear oil is fine.
Posted on Oct 17, 2013
  • 422 Answers
As much as the bowl can hold
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Hobart Master
  • 102,366 Answers
How many liters of oil for what?
Why can't I remove the whisk attachment?
forgot to push up before turning possibly
Mar 21, 2016 | Cuisinart SM-55 Stand Mixer
I have moved not to long ago and are kitchen aid mixer was in a box and laying on its side and there was oil all over the inside the box was soaked in oil . how do i check the oil level and what type of...
Wipe the oil up and use it. The machine has no oil in it, the grease is degrading and the oil is coming from there. It will be fine, next time it needs work done on it have them change the grease in the gearbox.
Dec 07, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
What qt size is this mixer
the bowl size is 5 quarts (4.7 liter) .. a very well liked machine
here is some further information
http://www.shopping.com/xPO-Kitchenaid-K5SS-Multiple-Colors
Aug 11, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I have model A-200-D Hobart mixer. Serial # 1575984. It is leaking oil into the bowl. Who can I call to get an estimate to service or repair this machine?
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
May 16, 2010 | Food Mixers
I have a v1401 and its oil level is low. Where
you can buy @any hobart office in your area.
Jan 15, 2010 | Food Mixers
Leaking oil
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jun 27, 2009 | KitchenAid Classic Stand Mixer
Oil change for hobart h-600 mixer
Needed to know which part to open up to add or change oil on Hobart Mixer h-600
Mar 05, 2009 | Hobart H600 Stand Mixer
Hobart 140 Qt Mixer 4 speed. needs the oil changed? what kind of oil to use?
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Jul 24, 2008 | Hobart H600 Stand Mixer
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
133 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
