Question about Plumbing
Concinnity faucet diagram
Our kitchen wall mount bridge faucet is leaking. Model KBW-L A diagram of how the faucets are assembled would be helpful. thanks!
arealplumber
  • 33 Answers
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Posted on Dec 05, 2008
  • 297 Answers
SOURCE: I have purchased a Tuscany Brass kitchen faucet
if i remember correct this connection is plastic to plastic,if this connection is broken you must replace the hose and the head.i hope this helps.good luck with you project.
Posted on Jul 31, 2009
SOURCE: 533-50 kitchen faucet leaks above base mount at
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
SOURCE: I have a Hansgrohe kitchen faucet model P-IX
Is this the Axor model with one handle? Of so you need to get a new element - the central piece inside the faucet - from Hansgrohe which costs about $45. It comes with a little repair kit that has very low quality instructions.
You need to use a metric tool #3 to unscrew the little piece in the back of the handle - then the handle comes off. You have to pull it hard to get it off.
The repair kit that comes with the element has a tool to screw off the main collar of the faucet and pull out the old element. The tool is a piece of junk that bends out of shape immediately and doesn't open the collar, and possibly cuts your hand in the process. Somebody at Hansgrohe was too busy having a coffee break to figure out that by the time you repair one of these units, it's probably been in service for several years and has a good deal of corrosion and means you need to good solid tool to unscrew the collar. The tool they send is pathetic. It's actually better, if you can, to use the side of it across the two niches in the back of the collar to make the turn. You may need to give the collar a few whacks with a small hammer to loosen it, but be careful not to hit the visible part of the faucet, is it will dent easily and not look so great after you complete the repair. Once you get the collar out the replacement isn't very hard. I've done this repair twice and am so irritated by the lousy instructions and bad tool that I'll never buy another piece from Hansgrohe.
Posted on Jan 10, 2010
My american standard model 4040 faucet is leaking at the base of the spout.
I checked online at www.plumbingwarehouse.com/american-standard-kitchen-faucet-hamilton-4040. There is a diagram that shows a seal kit that probably needs to be replaced. The diagram is really good and shows a complete breakdown of your faucet. I hope this helps.
Apr 10, 2015 | American Standard Plumbing
Installing concinnity replacement cartridge
I found cartridge for concinnity on amazon, here: NEW CONCINNITY BARAND Single Lever Faucet Cartridge Part No 30820 24... I hope this was helpful. cheers
Mar 04, 2012 | Plumbing
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
My Delta Faucet Leaks
Check that we were looking at same parts diagram, but I would say RP-70 Ball assy., as well as RP-4993 Seats & springs . If it's only dripping, just seats and spring will usually get you by, but if they are sending parts, free of charge, or ball assy., isn't too expensive, I'd change it too. I have had some luck with removing ball assy, cleaning it well with fine steel wool, then removing seals, and springs, stretching spring slightly, to add more pressure to seal, clean seal, then dab on a little vaseline to seals, and re-assemble.
Jan 06, 2010 | Delta Model 470: Signature Kitchen...
The cartrige inside my moen faucet leaks
moens website. they have parts break down and diagrams
Nov 30, 2009 | Moen F7425 Chateau Single-Handle Kitchen...
Need to buy a peerless wall mount kitchen faucet P 99305 from :cathat3springs@hotmail.com...... need help!
Peerless happens to be a less than preferred brand. If you go to www.peerless.com, you will find the model type. Try it, you may be able to order it online. haven't seen it around.
good luck.
Oct 09, 2009 | Peerless Industries Peerless Wall Mount...
Faucet leaks above ball assembly when using cold water
you have an 0-ring under the neck that has gone bad,you can replace this yourself if not a plumber can.
Jul 21, 2009 | Delta Model 470: Signature Kitchen...
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Plumbing Logo
78 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
