Question about Amscan Tiki Bubble Machine
I bought some tiki bubble machines from party city and found out the wands do not spin for the bubbles to blow out. Can it be fixed? I can't return them unfortunately, because I shipped it to Africa
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
The belly is full of bubbles and the batteries are in. i can feel it blowing air, but no bubbles come out
Check to make sure the path the bubbles take out is clear of anything in its way. There are also many reviews on this item that say this item does not work the way its suppose to. If you can not get this item working i would suggest taking it back to get a different bubble machine.
May 29, 2011 | Little Tikes Bubble Bellies - Boubly...
Zero steam from steam wands. No pressure.
First thngs first, make sure knob is turned to 2, then make sure there is water in the boiler, then turn machine to 0, remove back panel and reset thermostat on top of back boiler, if your machine has that feature installed. Then turn machine to 2, open one of the steam wands, If within 10 minutes boiler does get hot or there is no water bubbles, from steam wand, then the pressure stat might be damaged and needs to be replaced.
Apr 14, 2011 | La Marzocco Linea Series Group 3 Espresso...
Spins but doesn't drain
MAKE SURE MACHINE IS TURNED OFF. TAKE THE WASTE PIPE OFF OF THE SINK DRAIN PIPE AND BLOW UP IT AND LISTEN FOR BUBBLING IN THE MACHINE. IF YOU DONT HEAR ANY AND IT IS HARD TO BLOW ITS JUST A BLOCKAGE. KEEP TRYING THE BLOCKAGE USUALLY CLEARS. IF IT DOES REPLACE PIPE AND RUN MACHINE ON SPIN CYCLE THEN REPEAT.
Oct 01, 2010 | Speed Queen AWS52NW Top Load Washer
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
May 20, 2010 | Intex Easy Set Pool 15x36
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
The black plastic panarello (inside the steel cover) on my Saeco incanto deluxe is broken. Where can I order a new one?
I find that the panarello on the Vienna oveer-froths the milk and makes too many large bubbles as opposed to the preferred micro bubbles. The Gaggia Panarello Replacement Wands will work as a better replacement and the stainless steel one makes much better foam. I found Seattle Coffee Gear sells them for a reasonable price, $40 for the Stainless, and $20 for the plastic:
http://www.seattlecoffeegear.com/SearchResults.asp
Feb 12, 2010 | Saeco Vienna De Luxe Espresso Machine
Fisher pakel washing machine is not draining or spinning what should I do?
The valve is stuck or dirt is in it. To fix blow in the drain hose of the washer about 3-7 psi enough to hear the air bubbles in the bottom of the tank, it might take more then one shot you can blow with the mouth but not with a air hose at 50 psi the valve and hose will not like it. It has always fixed mine, good luck. To check run in spin the last led red the water should run out.
Nov 17, 2009 | Fisher and Paykel GWL11 Top Load Washer
My machine seems to be blowing bubbles in the
Hi
Sounds like you need a new pump. The internal check valves are stuck. I have seen them on ebay. Ulka EX5 is a good substitute.
Oct 19, 2009 | FrancisFrancis! X5 Espresso Machine
I have my Incanto Deluxe for about 1 year. I have never had any problem making a good quality froth, but recently the frother is producing too much air and milk is becoming bubbly. I am religesly clean my...
I think you have a chrome steam wand end.
To froth properly, there is a very small hole on the side of the chrome steam wand that injects small bubbles into the milk, the hole is located aprox 1/4" down from top of the chrome wand, if this hole blocks up you can only heat the milk, not froth. I commonly use a stripped tin tie wire or a sewing needle to clear the hole . Clean the hole,do not enlargen the hole.
Mar 02, 2009 | Saeco INCANTO DELUXE Espresso Machine
Amscan Tiki Bubble Machine Logo
43 people viewed this question
Top Amscan Toys Experts
ray gallant
Are you an Amscan Toy Expert? Answer questions, earn points and help others
