Question about Whirlpool Refrigerators
Whirlpool refrigerator ed2kvexvq01 leaking water underneath
SOURCE: Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Posted on Nov 12, 2008
SOURCE: My Whirlpool refrigerator leaks water
I also could not find the drain plug that everyone is saying to clean out. The only obvious things were styrofoam coated vents that went down to the fridge.
I have the same fridge with the sheet metal and cardboard in the back. My mfg. date is 6-04. That date is found near the ser. # and model #. My Whirlpool model # is ET1chmxkb03 THERE IS NO DRAIN TUBE RUNNING DOWN THE BACK!! It is all internal. Here is how I fixed the problem.
First, unplug the fridge. Empty all contents from the freezer and remove the shelf. Your food will be fine. Tell your wife not to worry!! You're going to need to remove the entire back panel of the freezer. Not hard. Remove the ice maker by unscrewing the single bottom screw and LOOSENING the two screws located above the ice slots. No need to remove them. they simply hang the icemaker in place. unplug the wiring assembly from the ice maker. set ice maker in sink if it has ice in it.
I had a lot of ice in the bottom and back of the freezer so i carefully chiseled and cleaned as i went. try using some hard plastic pointy thing to chisel. if that doesn't work use a screwdriver VERY CAREFULLY. I am not responsible for damages. ha.
the plastic "Y" shaped piece that covers the fan needs to come off. gently push down from the top to undo the two tabs that are holding the top to the wall. any resistance you feel is ice holding everything together. a hair dryer can also be useful to loosen things up. its going to get watery so keep towlels ready to sop up.
After the "Y" piece is off, you should only have two nuts or screws at the top of the panel. undo these and work off the panel. careful to push the wiring harness through the hole and the ground wire simply clips on the metal panel.
if you have a lot of ice at the bottom you'll feel resistance getting the panel off. scrape off as much ice as you can from the bottom and work the panel back and forth until it comes free. there is nothing holdin the panel in place at the bottom. it's just the ice.
when the panel is off you'll seea thin aluminum pan at the bottom probably covered in ice. keep chiseling (carefully) and you'll come across the drain hole everyone keeps telling you to unplug. this is the start of the tube that comes out into the pan under the fridge. i kept chiseling until there was no ice left anywhere in the freezer. always wiping and cleaning with the towels. there is also ice under the thin aluminum sheet. try to find a way to get this ice out too.
i tried several ways to get the ice out from inside the drain tube. even a little salt. boiling water from a turkey baster worked the best. my ice was frozen down about an inch so it took a few tries.
my drain pan was bone dry at the beginning of all this so i kept looking for water down there. finally it showed up.
pour little extra hot water down there for good measure and if you have some kind af flexible tubing to snake down there to clean it out it would be a good idea. 1/4 inch fish tank air tubing woorks pretty good. there are some bends in the drain tube so you might have to work it down.
hopefully this will fix the problem. reverse the steps to put everything back together being sure to reclip the groundwire to the icemaker. put the food back in the freezer and tell your wife instead of griping about the food being left out, maybe she should thank you for being a he-man and saving the family $500 by fixing the friggin thing yourself!!
Posted on Jan 16, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
aasc
  • 1606 Answers
SOURCE: water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Posted on Sep 02, 2009
Testimonial: "Thanks for the suggestion. "
heatman101
  • 43501 Answers
SOURCE: Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 02, 2010
Why does my whirlpool ET25DQ refrigerator leak water?
If your refrigerator has automatic defrost, the defrost water should drain from the bottom rear of the interior into a drain pan underneath. The pan may be missing or damaged or something could be preventing the defrost water from draining into the pan
Aug 05, 2013 | Whirlpool Refrigerators
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
The Whirlpool side-by-side refrigerator, model ED2KVEXVQ01 occassionally leaks water onto the floor. There could be a cup or more of water, but the problem has occurred a few times, but may go weeks or...
sometimes we overload our refrigerators and the doors will not close properly, next time you notice the water see if your doors are closed tightly and the seals engaged tightly. My wife has this habit of not checking after she has put away the remains of a big dinner or BBQ and I find drips of condensate water all over the floor as a result. The defrost collection pan overfills and the excess water goes on the floor. once the doors are closed properly the problem goes away.
Aug 03, 2010 | Whirlpool ED2KVEXVQ (217 cu ft) Side by...
Refrigerator leaks water on the inside underneath the freezer
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool ET1FTKXK Top Freezer...
Ice maker on ED2KVEXVQ01 is making hollow brittle ice. could the fill line be the issue?
This problem is the result of several factors that can be change only by checking the water fill level, time to fill and when and how long the heater element below the ice maker comes on. Also the direction of the water flow when the water comes into the ice maker. If fill tube is leaking water will be going to other places in your refrigerator. Most ice makers are around 7.5 seconds of time to fill. Your fill tube if freezing at end would be related to a defective water control valve. The time of fill and sequence of events is determined by the module in the front of the ice maker. I will need to go deep into my records to pull up that module adjustment for you but when they change setting that is a sign that it may be wearing out. Let me send you a parts manual and user manual and the part number for the complete module is W10190966 Be Right Back, Sea Breeze
Mar 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is leaking onto the floor from underneath the refrigerator.
There is a condensor tray located underneath. It catches water and then the water evporates. Sometimes the tube gets plugged and causes a mess. Check the tube and the condensation tray. You can access the tray by just taking off the grille under the door on the front of the refrigerator.
Nov 17, 2009 | Whirlpool EL7ATRRKS Refrigerator
Small pool of water underneath Whirlpool fridge
There may be a water filter built in. Look for access lower front panel below door. recommend replace every year. They will leak when neglected.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is leaking really badly underneath my Whirlpool refigerator.
I had this problem. Check you water line leading to your ice maker. the plastic section of it running up into the freezer cracks and leaks. easy fix, replace the tubing if it's leaking.
Jul 12, 2009 | Whirlpool Refrigerators
Refrigerators Logo
95 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
