Question about Lithonia Lighting 2 Head Emergency Light Elm2
2 HEAD EMERGENCY LIGHT WILL NOT LIGHT UP - Lithonia Lighting 2 Head Emergency Light Elm2
How do I open the fixture to change the battery?
usually there are clips or snaps and screws that hold it together
Mar 02, 2015 | Lithonia Lighting 2 Head Emergency Light...
How do i make a strobe light to flash
The relay for the circuit will also have been removed so that what you are trying to do cannot be achieved. This relay is generally one of a matched pair specific to each build of vehicle and together they control the other emergency functions like alternating head light flashing etc. You will need to obtain a wiring diagram for the build of vehicle you are using and from this determine the location and coding for the relay(s) which have been removed.
Jul 22, 2014 | Cars & Trucks
My thermostat has both auxillary and emergency light on,both are green,what does that mean?
Aux light; This turns on when the auxiliary (second stage) heating is in operation
It turns on 1-6 F below first stage and is user adjustable
Emergency light; This light turns on whenever the emergency heat is manually selected
(Mode switch is in the EMER position)
While in the emergency Heat mode, the heat pump compressor is off,
and the emergency heat (same as the auxiliary heat) maintains the
set point temperature
Jan 22, 2014 | Computers & Internet
Hyundai Sonata 2004 turn signal does not work properly
did you check the directional switch. sounds like you have a bad one
Nov 07, 2012 | Hyundai Sonata Cars & Trucks
My dashboard light isn't working but my turn signal light, emergency break light and all other warning lights work, just not the backlight so I can see the speed i am travelling in the dark.
Did you try turning the wheel/knob next to the head light switch? It's the dimmer for your interior lights. Sometimes that happens and some ppl don't know about it. Not sure how familiar you are with it so thought I'd throw that out there.
Oct 28, 2012 | 2002 Chevrolet Malibu
Hello, i have a carerra 911. i disconnected the battery as i will be out for a while, but i accidentally shut the hood all the way. usually i keep it slightly open so i can open it since it is electrical....
Hell there
Porsche made for this reason Emergency release cable.
The emergency release cable is located inside the top of the passenger front wheel well liner.
Remove the liner then the cable is near the head light ,
.this should do it for you
proporsche
Feb 22, 2011 | Porsche 911 Cars & Trucks
Mx7000 how do i wire it
I have a mx7000 lightbar but the switch for the front flashers will only go on if the the main lights are on any ideas on how to resolve this issue.
Sep 06, 2009 | Head LOT OF 4 ADJUSTABLE HEAD EMERGENCY...
Lithonia Lighting 2 Head Emergency Light Elm2 Logo
62 people viewed this question
Top Lithonia Lighting Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Lithonia Lighting Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
