Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Give me Hi, prob is that my pc is restart after boot window & again & againg now plz solved this problem.
    Scholar:
  • 151 Answers
Open your pc in safe mode. For opening your pc in safe mode: During system reboot press F5 or F8 All the options mostly like this will come: 1)Normal Windows. 2)Safe mode. 3)Safe mode with command promt. Select safe mode option. Then go to Start-> Run -> type 'msconfig' in it In msconfig -> Startup -> Uncheck the Reboot option. Your pc will not restart again and again.
Posted on Sep 26, 2007
  • 76 Answers
Please reinstall your windows...
My laptop(gateway nv53a) turns on but why does it only indicate "starting windows"?
Hi
The boot up files have become corrupt
you have to get the windows install disk
to match the windows installed on your
PC/laptop
Boot from disk and when its loaded it will give
you the choice to install or repair
chose repair and follow the promts
reinstall boot up files and then restart
if it still dosnt start
repeat process and this time
reinstall master boot record MBR
and restart
if that dosnt start you will have to
reinstall windows
25671898-m35oz4jvdfvvmght4a51n0jl-3-1.jpg or
or
cheers
Apr 29, 2015 | Computers & Internet
PC boot problem
Hi Jimmy,
Does the PC load windows fully before restarting?
If it does load and then restart,then it may be a problem on the part of your hard drive.
Run a full scan of the PC with an updated anti-virus to rid off any viral attacks.Make sure the anti-virus is always updated for better performance.
If it does not load windows,try this:-
  • Restart the PC.
  • Before it loads the first page,press Ctrl,Alt and Del.This is a soft boot sequence.
  • The booting leads you to the Bios setup page.
  • Under file save changes and exit[though no changes made].
  • If problem not solved repeat the procedure again.
If the problem persists,you may have to reinstall the operating system again.
Hope this helps.Thanks!
Nov 05, 2011 | HP 2133-1 Mini-Note PC
My 250 gb hdd is not pick the windows more than 1 day and experts aske to re create partition then i re create but the broblem still the re create of partition effects is that the windows in not wipe......
reformat your pc, and change the boot priority. make your hard drive to be the no.1 then cd-r to no.2 followed by floppy. you can set the boot priority from the bios set up just click delete when the windows restart.
Sep 25, 2009 | Computers & Internet
Computer wont boot
You will have to repair this file using bootable Windows Xp cd.
This problem will be solve.
Insert bootable Windows Xp cd and then press any key for boot.
When option appear for repair and write there Repair=R then you should press ' r ' and then you should follow the instructions.
Good Luck
Sep 24, 2009 | E-Machines eMachines T3830 PC Desktop
Same prob
This problem cannot be solved by anyone but a trained technician.
It will liklely requires one of the following repairs
1) new motherboard
2) new CPU
3) New CPU fan
4) new ATX power supply
This is my honest opinion after 100+ PM repairs personally.
best of luck,
Sagacious1
Aug 07, 2009 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
When turning on my averatec 3200 notebook it never
tap the f8 key as the PC is starting, when you see the startup menu, select,"disable automatic restart on failure", then you will be able to see the "BSOD" (blue screen of death), and it will tell you what the error that is causing it not to boot. you can also choose from the f8 menu "Last Known Good Configuration" and see if it will boot to the desktop, if not try safe mode, with or without network support depending on your preferences, your problem is most likely caused by a recently installed Windows update, or driver update, or some other software install, if its not clear to you from the info you see on the BSOD, try to use the system restore feature, and roll back to a date it was working, if it solves your prob, pleas give me a fixya rating. Thanks
Jun 15, 2009 | Averatec 3200 Notebook
Windows prob
GOTO-BOOT OPTION IN BIOS- THEN SELECT THE PROPER BOOT OPTIONS- FIRST GIVE PRIORITY TO CD ROM THEN TO HDD-
IF STILL YOUR UNABLE TO BOOT IT UP GO TO THE BIOS AND THEN USE THE DEFAULT SETTINGS... IT WILL BE THERE SOMEWHERE .
May 13, 2009 | Microsoft Windows XP Professional SP2
My Toshiba Satellite A215 - S4747 won't restart
Try to do fixboot.
Boot your computer from the installation disk,Enter in to the Recovery console by pressing
"R" when prompted>type the administrator password if any or in most of the cases its Blank
so just press Enter>on command prompt type,-"fixboot">restart windows normally once done.
if "fixboot" doesn't work, follow the above steps and try "fixmbr" this time, now should be
working fine..
plz let me know if this solves your problem.
your feedback is appreciated :)
Mar 26, 2009 | Toshiba Satellite A215-S4747 Notebook
Booting problem
RIGHT Click...
My Computer
From the menu choose Properties
Click the Advanced tab
Click Startup and Recovery
Under the system failure area take the check OUT of the box that says Automatically Restart.
Windows XP sucks on 128MB, get yourself more memory, go to 1 Gig.
Your problem could also be hardware such as a power supply so re-comment if the suggestion did not work for you.
**Please add a comment before giving a rating other than Solved
Oct 18, 2007 | Microsoft Windows Xp Home Edition Sp2...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
