Question about Brother MFC-685cw InkJet Printer
How to reset the purge counter in Brother MFC -685CW
SOURCE: Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Posted on Feb 19, 2009
techbuster
  • 5081 Answers
SOURCE: How do I reset the drum counter on MFC-9440CN
To reset the drum unit counter, follow the instructions below:
  1. Press Menu on the Control Panel.
  2. Press the Up or Down Arrow key to select Machine Info..
  3. Press OK.
  4. Press the Up or Down Arrow key to select Reset Menu.
  5. Press OK.
  6. Press the Up or Down Arrow key to select Drum.
  7. Press OK.
  8. Press 1 to reset the drum unit counter.
Posted on Aug 31, 2009
Testimonial: "THANK YOU THANK YOU THANK YOU Quick response and WONDERFUL HELP TO START MY MONDAY:)"
SpideRaY
  • 687 Answers
SOURCE: DCP-340CW purge counter reset
n the mean time you can RESET this purge count back to zero using the MAINTENANCE 80 menu, to continue using the printer for a while until you get the new pads. But it on a tray as if they are full they may start to leak onto your desk....
1 . Press (MENU) (MONO START) then (^) OR <the up arrow> four times, the Photo Capture and Red Exclamation Lights will then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4. Press the (MONO START) its a toggle until you see PURGE:6451 ( I guess this means you have cleaned the heads over 6,450 times their threshold level.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
Its the PURGE that will increment by a variable amount each time you clean the print heads the amount will be between 100 and 130. When this count gets to about 64,000 the error 46 will occur. That's about 510 times you can clean the heads before the pads need cleaning.
Almost forget to EXIT the Maintenance mode enter 9 twice by using the up arrow & set key's to exit from maintenance mode in the same way as entering the 2783 code, or power down the printer.
LOL
Check me out at www.windowstipsclub.co.uk
Posted on Sep 23, 2009
pineworks
  • 4041 Answers
SOURCE: unable to change 4f
Hi there
Brother 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Apr 25, 2010
pineworks
  • 4041 Answers
SOURCE: brother mfc 685cw jammed then get error message
Hi can try this
Hi there
Brother 4F
I have a brother mfc 3360C fax and it gives me error message 50.How do I reset the machine.
How to the Reset Purge Counter on a Brother Printer (With a Numerical Pad)
The 'Unable to Clean: Machine Error 46? message prevents you from printing on your Brother inkjet printer. It is especially frustrating when you realise there no reason why you can't carry on printing other than this message. Continue reading to find out what makes me say this and how you can rid yourself of this error.
This guide will deal specifically with Brother inkjet printers that have a number pad on the front of the printer. If you printer has a touchscreen as well as a numerical pad please see here. If however your printer does not have a number pad at all, the guide found here should be of use.
What is Error 46? 'Error 46: Unable to Clean' indicates that your Brother printer believes the ink absorber in the base of your printer is saturated with ink and any further printing could cause ink to overflow. How full this waste ink tank is has been estimated by monitoring how many pages your Brother printer has produced and how many manual/automatic cleans have performed. Sadly this is not a particularly accurate method of measuring how full an ink absorber is and the majority of the time your printer could prints hundreds of pages before there was any danger of any ink escaping. However getting the waste ink tank changed and resetting the counter can be an expensive procedure if you get a service centre to do it on your behalf. In many cases owners of Brother inkjet printers report the cost of the procedure outweighs the value of their printer.
With this in mind we suggest resetting the purge counter of your Brother printer using the method described below and continuing to use it until waste ink begins to overflow inside/outside the printer. This ensures you get the most out of your printer and can avoid replacing it until it becomes necessary to do so. I do however recommend you protect any surfaces around the printer should you decide to reset the purge counter to save any surfaces becoming stained with printer ink.
What printers will this reset work with? This reset procedure should be compatible with almost any Brother inkjet printer with a numerical keypad on the printer itself (and not touchscreen panel) and has been tested on every current compatible printer at our disposal. You can find a full list of compatible printers below:
Brother MFC-210C, MFC-215C, MFC-3240C, MFC-3340CN, MFC-3342C, MFC-410CN, MFC-420CN, MFC-425CN, MFC-5440CN, MFC-5840CN, MFC-620CN, MFC-640CN, MFC-640CW, MFC-820CW, MFC-235C, MFC-260C, MFC-240C, MFC-3360C, MFC-440CN, MFC-465CN, MFC-5460CN, MFC-5860CN, MFC-660CN, MFC-665CW, MFC-680CN, MFC-845CW, MFC-885CW, MFC-250C, MFC-255CW, MFC-295CN, MFC-297C, MFC-490CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-990CW, MFC-J615W, MFC-J220, MFC-J265W, MFC-J410, MFC-J415W, MFC-J430W, MFC-J5910DW, MFC-J625DW, MFC-J6510DW, MFC-J6710D, MFC-J6710DW, MFC-J6910DW, MFC-J825DW
If you have a printer with a numerical pad not covered above and find the purge counter reset works for you then please let us know so we can update our list.
Video Guide Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
I hope you have found this guide useful. If however you have anything to add or any further questions please don't hesitate to let us know in the comments.
Jun 02, 2015 | Brother Office Equipment & Supplies
How To Reset Purge Counter on a brother mfc-j4710dw
Mar 03, 2014 | Brother MFC-J4710dw Color Inkjet...
How do you resets the purge counter
Press buttons 3 and 9 at the same time in the ready state, the RESET MENU/DRUM will appear on the LCD. Resetting the purge counter is not included, Just to give you an idea.
Apr 17, 2013 | Brother MFC-9440CN Laser Printer
Unable to change 4f error on Brother MFC-685CW
Hi there
Brother 4F
Apr 11, 2010 | Brother MFC-685cw InkJet Printer
Brother mfc 685cw jammed then get error message unable to print 4f, what does this mean? Can;t get it to clear after following brother steps to clear it
Hi can try this
Hi there
Brother 4F
Mar 12, 2010 | Brother MFC-685cw InkJet Printer
I reset the purge counter on the brother printer MFC210C now error A7 appears, don't know what to do now.
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Mar 03, 2010 | Brother MFC 210C All-In-One InkJet Printer
I need a cd for my mfc-685cw brother prenter pl
You can download your mfc-685cw brother printer drivers, utilities, and firmware or you can download it all in this link: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc685cw_us_as
Dec 13, 2009 | Computers & Internet
Machine error46 by brother-dcp330c
Symptom :
error46
or
the number of performed purge sequences has reached the limit.
or
The number of flushing operations has reached the limit.
Probable Cause:
1/ Purge counter overflown
2/ Flushing counter overflown
Solution :
Replace both the ink
absorber box and flushing
box and reset their
counters. (When you need
to replace the ink absorber
box or flushing box,
replace both.)
Mar 27, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-685cw InkJet Printer Logo
47 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
