Pentium 4 computer-ABIT motherboard-continious beeps
I upgraded the memory about 3 weeks ago. Everything is running fine, except there is a continious beep from the time the "A" drive is checked for a bootable drive untilI load the Abit monitoring program ABITEQ and then it stops. How do i find the cause and how do i fis the problem? All ideas are welcome?
  • frustratedaz Sep 29, 2007
    The drives are not the problem. I mentioned the 'A' drive only to give you a point of reference as to when it starts.
  • 35 Answers
Go into the BIOS and change the booting order so I does not include the Floppy (A:) drive.
Posted on Sep 29, 2007
    Problem Solver:
  • 7 Answers
Go to bios and than disable a drive than u don't hear a beep about ur a: drive bye bye
Posted on Sep 26, 2007
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
I also have an nf7-s no video or beeps
The one thing that people should stay away from is the Motherboard! It may be fried to use your word, but a Motherboard is not a french fry to be fried. An MB is a complicated and multiple task board that, once to find the fault, it takes pennies to fix it. The way you talk it seems that the computer is old and slow and antiquainted. If that is not so, then send us the following information: (1) Name of Mnufacturer and Trade Name of Computer; (2) Model Name and Number; (3) Motherboard Identification Number. If you have a problem we can help you find it. (4) All details of what happened when you tried to turn it on. Also under this, we would like to ask you what type of Memories are used. Thank you for your consideration of choosing our service. CONSTANTIN (arzconst)
Jul 05, 2009 | Abit NF7-S V2 Motherboard
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
OS does not boot
Hello there.
Most likely the new stick(s) of memory is causing problems in your system. To verify this i would remove the newly added ram and see if the problem goes away.
Also you can download and run a memory test called 'memtest86+' from here. This can be burned to a cd and booted from the computer, to run a diagnostic on the new memory.
Hope this helps.
Apr 15, 2008 | Intel BLKD915GAVL (BLKD915GAVLX10U)...
Max CPU for abit BL7-RAID
As number of cpus it supports maximum one cpu.
As cpu type it has a socket 478 supports any pentium 4 (not duo) up to Pentium 4 2.8G (p.n:RK80532PC072512)
You may need to upgrade bios to latest version to support the CPU.
Apr 09, 2008 | Abit BL7-RAID Motherboard
Computers & Internet Logo
249 people viewed this question
Alun Cox
David Payne
David Payne
