Convergence I am technician and I have problems with my tv, I changed the convergence ICs but I found that resitors R3159 and R3160 are burned and I can't see the values of them. Can you help me to get those values ? Thank you Nanu
  • b3tyboop Nov 05, 2007
    my sony has 3 different colorand 3 people and shadow i thinkits the ic convergence.my model no is kp-41exr96. year 1997 thank you
I have a daewoo dsj-5510cra i replaced the convergece chips and con't adjust them what else can i check?
Posted on Sep 27, 2008
Nana
Look under the chassis on the bottom right side. I found a sheet that describe most of the componet values
Good luck
Posted on Jul 06, 2008
SOURCE:
Jvc av-48wp30 blue to align convergence
Tv colors R,G,B don't alignment any colors.Tv have a convergence problems,it dead.Tv convergence board require changes 2 STK convergence ICS and some or all it resitors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 11, 2010 | JVC AV-48WP30 48" Rear Projection...
Picture looks like 3D tv without the glasses on. What's up with that?
Ur tv have a convergence problems,it dead.The convergence board have 2 STK convergence ICS,and some or all it resistors are dead.U must know how to solder,have soldering tools,and solder to solved the convergence problems.U must replaced the 2 STK convergence ICS,and some or all it resitors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
May 14, 2010 | Philips 51PW9303 51" Rear Projection...
Color convergance will not manually adjust, what could be wrong with my set?
Convergence it dead,require change two convergence ICS and all it resitors.Know how to solders.Tries Tv repair World.com,Tvrepairkitscom for the convergence to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 03, 2010 | Toshiba 42H83 42" Rear Projection...
Seeing double
need to replace the convergence ICs and possibly the convergence resitors . You need STK392-110 ICs you can get the ICs and the convergence resiistor kit for your model at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Jul 28, 2008 | JVC AV-48WP74 48" Rear Projection...
Convergence
Did you check the resitors out of circuit? As its very rare when a Hitachi doesnt open at least two on the affected circuit. If you checked the resistors in circuit an open resitor will read good even though its actually open.
Jul 08, 2008 | Hitachi 46F500 46" Rear Projection...
Projection tv problems
jj,
The convergence amps have most likely failed. This is the number one leading cause for the symptom your describing and the most common failure on that unit.
Your Tv take two STK392-120 Sanyo Ics for convergence amps, located at Ic7404 and Ic7405 on the board and mounted to a rather large aluminum heat sink. In addition you will most likely have to replace R3159 and R3160 (6.8 ohm 1w) resistors and test the remaining low ohm resistors for change in value.
I would strongly recommend that you not do this repair yourself in this particular unit it is rather complicated by having to remove the boards to gain access. Notwithstanding that you could damage some of the smt components just taking the board out, you need some diligence in labeling outputs to crts from ssb board and on both ends of the connectors - otherwise re-assembling it could cost you a greater failure somewhere else. In a nutshell, replacing convergence amps in this unit is "extremely difficult" compared to say a Samsung which is a walk in the park! And the real downside is a little mistake can really cost you... Besides, a shop would really earn their money on this one..
Bill
Dec 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
51mp392h
Unfortunately it sounds like the convergence amps have failed - either that or they have developed ring-cracks where they're soldered to the foil side of the pc board and moving the set broke loose some of the contacts.. Only way to know for sure would be to remove the signal board and inspect them.. Not a job for the less than qualified... Even techs find themselves confused for not labeling the output connectors to the crts properly..
Your set takes two STK392-120 Sanyo built Ics and upon replacing them it's a good idea to also replace R3159 & R3160 both 6.8 Ohm 1w resistors.
Hope this helps.
Bill
Dec 07, 2007 | Philips Magnavox 51MP392H Rear Projection...
Picture problems
A shop would really be earning their money on this particular unit if they charged $400 - $500 for the repair. It is an extremely difficult set to work on and there are a number of little problems that can reach-out and bite when attempting the repair.
Bill
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51" hdtv rear projection
Those symptoms describe a convergence failure. Replaced both Stk392-120 convergence amps made by Sanyo and R3159 , R3160 (6.8 ohm 1w) resistors and check the remaining low ohm resistors for change in value.
This is probably one that you'll want to take to the shop unless you have some fairly good skills in electronic repair. Job will probably be about $350 - $425 if you take the unit in yourself and shop around for a reputable shop.
Bill
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Ekse
