Question about Panasonic SA-HE75 Receiver
When turned on, it reads: "OVERLOAD". TURN of
When I turn on my receiver the "overload comes on ant it cuts off!
You were lucky the overload protection circuit kicked in, congradulation on finding it.
Mar 14, 2012 | Optimus STAV-3770 Receiver
Main breaker doesnt stay turned on
Tripping of the main breaker could be an indication of a short or an overload. To check for an overload you will need an amprobe to test the amperage load on the breaker. Turn all the secondary breakers off. Attach the amprobe by clamping it around one power wire. Turn the breakers on one at a time and check the reading of the amprobe. Most breakers will handle about 80 % of the breaker rating before tripping. If it trips below this point the breaker may be weak and will need to be replaced. If the amprobe pegs out at any time and the breaker trips the secondary breaker that was last turned on probably has a short in its wiring somewhere. Cuasing the breaker to trip. Underground wirng that has gone bad can sometimes take a while to trip the breakers so if there is any underground feeders it may be more difficult to track down a short. If the problem is an overload check both hot wire to see if the load is equal if the load is a lot higher on one leg than the other switching some circuits to the lower side may help. If the total load is just too high you may have to increase your service to a larger size. Hope -this helps
Bob
Nov 04, 2011 | Cutler Hammer 100 Amp Main Breaker...
JVC 6010V shows zero on volume wont go up or down
This is a fault on the D/A digital / Analogue converter , The volume control being analogue is not processing the data in the cicuit and so there is no change in the level. This can be a fault in the IC - the D/A convertor IC which is not giving any response with the turn of the potentiometer. So check this within the amplifier ONLY if you are able to trace the circuit and replace the IC connected to the potentiometer.
Oct 21, 2011 | JVC RX-6010V Receiver
Freezer turns off after 5 minutes then turns back on, then back off, then back on...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Place a probe on each terminal. The multitester should display a reading of zero ohms. If the overload protector does not pass this test, it should be replaced.
Feb 13, 2010 | GE Monogram ZICS360NR Bottom Freezer...
My pioneer amp vsx d508 reads overload.what to do?
Sounds like a bad amplifier IC.
Unhook all speakers at the back of your pioneer. turn it on and turn down the volume. If it's no longer in overload you have a bad speaker or speaker wires touching somewhere.
If its still in overload it's prlobley a amp IC and will cost between $25-$60 just for the part if you can replace it yourself.
Dec 27, 2009 | Pioneer VSX-D508
SXG490 displays
if overload warning displays only when you activate speakers "a",,, please check your wiring and speakers
for that channel, first remove both A speakers turn it on, if its okey plug one speaker and try again if okey remove it and try the other one, when you see which one is it check the wire and the speaker ( every time you hook the speaker turn it off before that) overload means something is shorting and that protects the unit to prevent furter damage
Dec 19, 2009 | Audio Players & Recorders
Vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Apr 20, 2009 | Pioneer VSX-517
What to do with the Total Blender when overload appears?
The product has a 3-year warranty:
A reading of “OVERLOAD” indicates an overload on the motor. Turn off
and unplug the unit. Plug in the unit and turn the motor on again to clear the
over-load condition. Check the blender jar for blockage. If overload condition
re-occurs, contact your Blendtec service agent.
Mar 25, 2009 | Blendtec ABC Work Top Blender
When i turn up the stero the power turns off and the red standby light flashes till i turn it back on
Firstly i would disconnect all speakers and turn amp up if still does it then there is an overload in amplifier anbd needs to be repaired..
If not then connect speaker 1 at a time and try amp volume again,you could also get a multimeter and check across speaker terminals on boxes for different resistance readings..
Jan 08, 2009 | Onkyo TX-SR601 Receiver
Kenmore freezer upright
The S terminal should read zero when you invert the relay. The M terminal should be zero at all times through the relay. If you follow the coil wires on the relay you will find they go from the line connection to the M terminal. M meaning main or run terminal. When current is drawn through the M terminal it pulls in the contact for start to the S terminal. When the compressor comes up to speed the current drops off and the start contact opens allowing the compressor to continue to run on the M terminal.
Sep 14, 2008 | Freezers
Panasonic SA-HE75 Receiver Logo
32 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
