Codigo aficio 650 dando erro 329 - Office Equipment & Supplies
KOakaKO
  • 135 Answers
SOURCE: SC 329 code Aficio 550
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the “Enter” key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Posted on Dec 12, 2008
  • 64 Answers
SOURCE: ERROR CODE SC329 IN AFICIO 450
Laser synchronization error
The main scan synchronization
detector board cannot detect the laser
synchronization signal for more than 5
consecutive 100 ms intervals
Posted on Jan 16, 2010
  • 64 Answers
SOURCE: ERROR CODE SC329 IN NASHUA AFICIO 3445
ca 107 c then inter the sp mode then clear error
Posted on Jan 18, 2010
rezazadeh
  • 328 Answers
SOURCE: codigo de erro E 7 MSE. AL 1645 SHARP
press copy after E7 code see sub code E7 with what?
Posted on Jun 01, 2010
  • 225 Answers
SOURCE: hp plotter T610 bacalhau. 21.1:03
The service station cannot move. Look for pieces of paper in there. Replace if broken. It's too dirty job to take apart the service station, to clean and find what is wrong with it.
Posted on Aug 05, 2010
Codigo sc 542 en ricoh sp 3510 como resetearlo
Oi por favor. Gostaria de resolver meu problema com minha impressora ricoh 3510sf que estar dando o erro sc542. Me manda resposta. emiliomartinscte@gmail.com
Apr 09, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
En mi maquina aficio 650 sale el codigo de error sc 462-00
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 14, 2013 | Televison & Video
Riso RZ200ep. como resolver o erro codigo A - 06 -403
Jul 08, 2012 | Office Equipment & Supplies
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
Sep 01, 2011 | OKI C5500n Printer
TENHO UMA RICOH 161 E DEU O CODIGO SC 819
Isso é um erro de firmware.
Existe uma actualização que corrige isso. Se tiveres acesso a descarregar os firmwares e se souberes como fazer... O teu problema está resolvido.
Contudo aconselho que ligues com a assistencia tecnica. Contacta com a Ricoh portugal e eles enviam-te um tecnico que saberá fazer isso.
Boa sorte.
Mar 01, 2011 | Ricoh Aficio MP 161 Black and White Copier
Tenho uma ricoh 171 esta dando erro sc500
You have a main motor overload. This can be caused by a defect in the photoconductor unit. Try putting an old photoconductor unit. If you still can not run the engine is broken
Dec 23, 2010 | Ricoh Aficio 1018 Printer
Hp plotter T610 bacalhau. 21.1:03 Erro - troquei Estação de Serviço / APC e continua Dando o Mesmo Erro
Aug 05, 2010 | HP Designjet T610 InkJet Printer
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
69 people viewed this question
k24674
jasbo
jasbo
