Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
INSTRUCTIONS TO REPLACE HANDLE FOR SAMSUNG SMH8165ST
How to remove grease filter from a Samsung over the range microwave model number smh8165st
The support page for model SMH8165S is here, and the first solution listed is how to replace the charcoal filter.
You can also download your owner's manual.
The charcoal filter is part number DE63-00367A and you can order it from the Pros here.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
May 01, 2017 | Samsung Microwave Ovens
How do you remove grease filter from Samsung over the range microwave model number smh8165st?h
pupista@gmail.com
I have a samsung microwave SMH8165St and the door handle broke, how can I change it?
Before install it you need to pre drill the screw hole one size bigger.
Then use clear silicone on base to help it hold to place better.
Factory uses a power drill . Do not use a power drill you bend the cpvc and crack it and you be in same spot again. (Hand Tools only)
Apr 26, 2015 | Samsung Microwave Ovens
I HAVE A SAMSUNG MICROWAVE MODEL SMH8165ST KEEPS BEEPING SE
"SE" error on a Samsung made microwave means you have a shorting membrane keypad.
This is a pretty simple DIY repair.
You would need part number DE94-01806C which you can get for about $68 from the Pros here, our favorite supplier.
Here's a YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then unplug the keypad strip and move your board into the new frame. Be careful, because the display is made of glass.
Some connectors on the relays have a lock:
Jan 29, 2013 | Samsung SMH9187ST Microwave Oven
My Samsung SMH8165ST Stainless Steel 1600 Watts Microwave Oven Problems
This indicates a system error, the keypad has a short in the membrane, the keypad control board will need to be replaced.
May 02, 2012 | Samsung SMH9187ST Microwave Oven
Samsung microwave oven smh8165st
If everything else seems to work, the magnetron is the likely problem which is the heart of the microwave oven, consideration should be given in replacing the microwave because of repair cost.
Apr 02, 2012 | Samsung Microwave Ovens
SE or 5E display on Samsung Model number SMH8165ST
This microwave is a piece of garbage and Samsung are a bunch of idiots. I have a solution but first I will vent. One day after my warranty ran out, I started getting this SE error. They referred me to an authorized repairman, who said it would be $200 just to come and look at it! Thats for a microwave that sold for slightly more than that new! Samsung refuses to offer any do it yourself help. Some guy who works on microwaves told me to order a new control panel. part DE94-01806C It was about 36 dollars and took about 10 minutes to install. If you want to save a little, for 24 dollars you can just replace the membrane. That requires removing the existing membrane with a hair dryer and then carefully applying the new one. Seemed like too much trouble so I went with the control panel.
Feb 04, 2012 | Samsung SMH9151 Microwave Oven
I have a Samsung household microwave oven model # SMH8165ST that when plugged in will beep a few times then blink "SE". None of the buttons will work.
Try calling Samsung....
Purchased samsung SMH8165ST in Oct 2009. have had the SE code problem for a few month now. Resetting worked at first. Then the light started flasing on & off along with the beeping...would not reset. Out of frustration I called Samsung. I was told they are aware of the problem & would repair in the "epidemic warranty". Repair man just left. It took him about 15 minutes to change out the keypad. No charge!!
Aug 30, 2011 | Samsung SMH8165STE Microwave Oven
Need owners mannuel for microwave, model # SMH8165ST
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, Driver downloads and Installation Instructions as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Jan 11, 2011 | Samsung Microwave Ovens
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
