Question about Keurig B155
System overheated - Keurig B155
Why did my 2011 DTS Cadillac overheat?
An overheated engine can be caused by anything that decreases the cooling system's ability to absorb, transport and dissipate heat; therefore engines can overheat for a variety of reasons. Let's take a look at some of the most common causes.
Cooling System Leaks
This is the primary cause of engine overheating. Possible leak points include hoses, the radiator, water pump, thermostat housing, heater core, head gasket, freeze plugs, automatic transmission oil cooler, cylinder heads and block. Perform a pressure test. A leak-free system should hold pressure for at least one minute.
Wrong Coolant Concentration
Be sure to use the coolant recommended by your vehicle's manufacturer. The wrong type of coolant and/or mixing the incorrect concentration of coolant and distilled water can also result in engine overheating. The best bet is to perform a complete flush and fill.
Bad Thermostat
A thermostat is a heat-sensitive valve that opens and closes in response to engine temperature. Heated engine coolant passes through to the radiator when the thermostat is in the open position. In the closed position, it prevents the flow of coolant to speed up the warming of a cold engine. When the thermostat gets stuck in the closed position, coolant stays in the engine and quickly becomes overheated, resulting in engine overheating.
Blocked Coolant Passageways
Rust, dirt and sediment can all block or greatly impede the flow of coolant through the cooling system. This can limit the system's ability to control engine temperature, which may result in higher operating temperatures and engine overheating. Once again, a flush and fill is recommended to remove debris.
Faulty Radiator
By passing through a series of tubes and fins, coolant temperature is reduced in the radiator. Leaks and clogging are some of the most common causes of radiator failure. Any disruption in the radiator's function can lead to elevated engine temperature and overheating.
Worn/Burst Hoses
A hose that contains visual cracks or holes, or has burst will result in leaks and disrupt the flow of engine coolant. This can result in overheating.
Bad Radiator Fan
A fan blows air across the radiator fins to assist in reducing the temperature of the coolant. A fan that wobbles, spins freely when the engine is off, or has broken shrouds will not be able to reduce the temperature to proper level, thus possibly resulting in engine overheating.
Loose or Broken Belt
A belt is often the driving link that turns the water pump at the correct speed for proper coolant flow through the cooling system. If a belt is loose or broken, it cannot maintain the proper speed, thus resulting in poor coolant flow and ultimately, engine overheating.
Faulty Water Pump
Known as the 'heart' of the cooling system, the water pump is responsible for pressurizing and propelling engine coolant through the cooling system. Any malfunction of the water pump, including eroded impeller vanes, seepage or wobble in the pump shaft, can prevent adequate coolant flow and result in engine overheating.
Oct 13, 2016 | 2011 Cadillac DTS
Tip
Overheating of car
HII,
NOTE: To avoid burns and injury, never, ever attempt to remove a radiator cap while the engine is hot!
An overheated engine can be caused by anything that decreases the cooling system's ability to absorb, transport and dissipate heat; therefore engines can overheat for a variety of reasons. Let's take a look at some of the most common causes.Cooling System LeaksThis is the primary cause of engine overheating. Possible leak points include hoses, the radiator, water pump, thermostat housing, heater core, head gasket, freeze plugs, automatic transmission oil cooler, cylinder heads and block. Perform a pressure test. A leak-free system should hold pressure for at least one minute.Wrong Coolant ConcentrationBe sure to use the coolant recommended by your vehicle's manufacturer. The wrong type of coolant and/or mixing the incorrect concentration of coolant and distilled water can also result in engine overheating. The best bet is to perform a complete flush and fill.Bad ThermostatA thermostat is a heat-sensitive valve that opens and closes in response to engine temperature. Heated engine coolant passes through to the radiator when the thermostat is in the open position. In the closed position, it prevents the flow of coolant to speed up the warming of a cold engine. When the thermostat gets stuck in the closed position, coolant stays in the engine and quickly becomes overheated, resulting in engine overheating.Blocked Coolant PassagewaysRust, dirt and sediment can all block or greatly impede the flow of coolant through the cooling system. This can limit the system's ability to control engine temperature, which may result in higher operating temperatures and engine overheating. Once again, a flush and fill is recommended to remove debris.Faulty RadiatorBy passing through a series of tubes and fins, coolant temperature is reduced in the radiator. Leaks and clogging are some of the most common causes of radiator failure. Any disruption in the radiator's function can lead to elevated engine temperature and overheating.Worn/Burst HosesA hose that contains visual cracks or holes, or has burst will result in leaks and disrupt the flow of engine coolant. This can result in overheating.Bad Radiator FanA fan blows air across the radiator fins to assist in reducing the temperature of the coolant. A fan that wobbles, spins freely when the engine is off, or has broken shrouds will not be able to reduce the temperature to proper level, thus possibly resulting in engine overheating.Loose or Broken BeltA belt is often the driving link that turns the water pump at the correct speed for proper coolant flow through the cooling system. If a belt is loose or broken, it cannot maintain the proper speed, thus resulting in poor coolant flow and ultimately, engine overheating.Faulty Water PumpKnown as the 'heart' of the cooling system, the water pump is responsible for pressurizing and propelling engine coolant through the cooling system. Any malfunction of the water pump, including eroded impeller vanes, seepage or wobble in the pump shaft, can prevent adequate coolant flow and result in engine overheating.ALSO IN THIS SECTION:HOW A COOLING SYSTEM WORKSSYSTEM MAINTENANCE & RED FLAGSCOMMON CAUSES OF OVERHEATING
on Aug 24, 2015 | Air Conditioning and Heat for Chevrolet...
Tip
How do I know if my laptop is overheating.
Hi.
Overheating may ocurr if the air vent intakes are obstructed, or when the cooling system is defective.
A typical symptom is the computer shutting down suddenly and turning off completely for no reason.
To start you need to ensure that the laptop is not turning off becauseof a system problem.Sudden shut down can be caused by differentsoftware and hardware problems. There are several ways to check thisout.
You can for example start the laptop using a boot disk, or starting aWindows setup disk, and then leaving the system on for one or twohours. If the system does not turn off after starting from disk, thenthe problem is not overheating.
If for example you decide to use a Windows setup disk to do the test, proceed in the following way:
  • Start the system with the Windows disk inside.
  • Choose to "start system from CD" when asked.
  • Do not choose to install or repair Windows, just start the system and leave it hanging on for some times.
  • Ensure that the computer does not go on standby in the meanwhile.
Another way to check if the problem is overheating is by using a software like SpeedFan to monitor the system temperatures.
That would be a better way to check if the system is overheating, as it can give you precise indications on system temperature.
If the system starts and stays on long enoug to install and then to start SpeedFan, then install the software and turn it on. If temperature before shut down is near to critical value, then the problem is overheating.
This last method can be used only if the system stays on long enough to start Windows and run the software.
If the problem is overheating , that means that the heatsink fan mustbe replaced, before overheating ends up damaging CPU or motherboard.
Please read more from my articles below:
Laptop is turning off by itself.
CPU is overheating
This tip apply to both laptops and desktop PCs.
Regards.
on Mar 12, 2010 | HP Pavilion dv6000z Notebook
Car dies when i come to a stop and when i drop to 1st gear
hi,
Jul 14, 2015 | 2003 Ford Escort - ZX2 - Ltd. Edition...
What could cause a Mercedes Benz to over heat and keep popping the hose off near the firewall
your building to much pressure and that's related to you overheating ,start by checking cooling system ,possible have it flushed out ,your thermostst my be sticking closed causing overheating, also check radiator cap ,if overheating it should blow off into expantion tank, make sure levels are full , some motors have air bleeder screws that remove the air in the cooling system and that will trap air in the cooling system causing overheating.
Feb 26, 2015 | Cars & Trucks
Overheating
About the only thing left is the water pump.
Mar 29, 2014 | Mercury Villager Cars & Trucks
Was overheating changed the water pump but still overheating
remove thermostat permanent for week and fit clean water and radiator flush 80 to 100 mg every 2 days then flush your system engine and radiator fit new cup ,new thermostat new antifreeze bleed your system,check for leeks and loose belt.if still overheating try t /k test.
Sep 01, 2012 | Cooling System for Mercedes-Benz C230...
I am getting an engine system failure light coming out on my 2005 ford focus. The first day I checked oil and water. The oil was slightly low and I topped up. The water appeared to be overheating and I...
Sounds to me like you are having a cooling system problem, if water is boiling in the tank or radiator then the engine is overheating. If you have not flushed the cooling system, it would be a good idea to do so. Also you need to test the cooling system at idle and see if the engine will maintain normal temperature, without overheating. Overheating can be caused by plugged or restricted radiator, hoses, or the thermostat, also check the operation of the electric cooling fan. Once you solve the overheating you light should stay off. If you do not solve the overheating soon, the engine will suffer major damage, so check it out very soon. Hope this helps, let me know.
Aug 04, 2010 | 2000 Ford Focus
My asus notebook m6b00 keeps overheating and tunring off why?
Laptop overheating has become a more common problem in recent years as both the CPU chips and the video chips in laptop computers have become more densely packed with transistors, all of which generate heat. With both CPUs and graphic systems generating more heat, laptops can overheat if they are not properly designed or if ventilation and cooling is interfered with. The problem is compounded when manufacturers put desktop components in mobile systems, or when laptop design does not properly provide for laptop cooling under foreseeable normal use of the systems.
Laptop overheating most commonly signals itself by sudden, otherwise unexplained shutdown of an operating computer. If your laptop computer suddenly shuts down for no known reason, there is a high likelihood that the fail safe software in the computer is shutting it down when the computer temperature gets too high. Other signs of overheating notebook computers include constant or excessive fan operation, unexplained memory or operation errors, and inexplicable “blue screens of death.”
The problem often arises when you are using your computer intensively in ways that keep the CPU operating at high capacity and the hard drive and video systems busy as well. Gaming often leads to laptop overheating. Virus scans, compiling software and similar intensive tasks can also bring on the problem. The problem also, not surprisingly, sometimes occurs when the temperatures are high in the setting where the laptop is being used.
The consequences of overheating laptops can be quite serious. Your computer can be damaged, and may end up requiring expensive replacement of major system components, such as motherboards or graphic cards. In addition, medical researchers have reported health issues ranging from sterility to burned genitalia related to use of overheated laptops by fully clothed users.
If you have an overheating laptop and your computer is still under warranty, you should promptly report the problem to the manufacturer and seek their help. Because many manufacturers seem to engage in denial rather than cures with regard to this particular problem, you should also read the information on laptop overheating on this and related sites so you can better understand the causes, the consequences and the possible cures for notebook computer overheating.
Here is the to see some tips on why your laptop is overheating.
www.yboyandrei.com/notips
Aug 08, 2009 | ASUS m6n Notebook
Keurig B155 Logo
93 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
