Question about Cameras
Se830 digital receiver
Lnb input should have voltage which provide the power supply for outdoor lnb, right now the voltage is zero, what component may be bad ?
  • 2318 Answers
SOURCE: directv h20 receiver has low volyage to the lnb.
Check inside the receiver for a defective LM317 IC or a TIP42C transistor, but before that you should check for proper voltage from the power supply to that IC.
LM317/TIP42C control the switching of voltages that power up the LNB, you should be getting 14 volts for vertical channels and 18 volts for horizontal.
Good Luck.
Posted on Mar 08, 2008
Benimur
  • 6966 Answers
SOURCE: no output from power supply
I am assuming that you are very familiar with electronic circuitry and components, use of a DVM and a soldering iron. In the absence of a schematic diagram, and since you have perform initial voltage checks, perhaps you can wing it. Your "brick" will have to follow the basic design of an SMPS (switch mode power supply). Simply stated,an SMPS is an AC to DC to high freq AC then to lo V DC converter. Per your post, you have checked that there is DC (B+) from the AC mains, then what is needed is to check if there is oscillation to produce the high freq AC. Often design calls for an optical coupler, a small rectangular looking component with four pins, two at each end. This is nothing more than a LED and a Light Dependent transistor. Its function is to switch/trigger on the oscillation (and therefore start the SMPS producing the lo B+s).
Again, since there is no readily available schematic diagram, might I suggest that you post back the part numbers of the ICs and transistors. What we can do is pull out their spec/data sheets and/or application diagrams. Such would give us a general idea of the working voltages at what pins and what each component is supposed to do. Example, let us say your power supply uses a 817A/0635 opti coupler and/or an SG5841DZ controller IC, then we can search for them as initially described.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 30, 2008
Slinteriors
  • 8617 Answers
SOURCE: POWER SUPPLY BAD, NEED SCHEMATIC DIAGRAM COMPONENT LEVEL
Polaroid will not release component schematics not even to service centers as they are designed to replace the entire modules while under warranty out of warranty there is very little Chance of obtaining new replacement parts. As i have a 2006 LCD and a 2007 Plasma Polaroids and polaroid told me they are considered a disposable TV replacement parts are not available and suggested that I try ebay
Posted on Apr 29, 2009
  • 5 Answers
SOURCE: input voltage ?? lost power supply WHP-150C
the adapter is a thomson output is 19v-200ma--neg polarity
Posted on Apr 07, 2010
SOURCE: Digital Stream HD 3150 OTA HDTV tuner does not operate
Disclaimer: The answer provided is entended for you to have some basic electronic knowledge and soldering skills.
Troubleshooting switching power supplies just sucks, but there are ways of finding the fautly componets. In my case, a visual inspection found 2 bad capitors, the tops bulging open and oosing goo. If you look at the tops of any other caps they should be flat. You can also note faulty caps by discoloration of the circiut board itself. I had one other faulty cap on my supply that, by visual inspection had been running hot. After replacing the defective caps (Nichicon 105c) I went with an ohm meter, and checked the smaller transistors for faults. Q1 a very common transistor was bad (2N3906) with a base emitter short. In conclusion, it's the cheap caps that are at fault, sometimes taking the silicon with them as they short out. The unit is now working.
As an added note, I understand that there is a Radio Shack branded version of the HD3150 as well.
Posted on Jun 12, 2010
remember to swtich the LNB power to ON in the setting menu.
if still no power, there is a power module on the board. may not be economical to repair
Oct 16, 2013 | Televison & Video
Bell 3100 satellite receiver
purchase a new receiver or previously owned , make cretin that there is no previous bill owing on the receiver, there is not much help regarding repairs, and it is legal to tamper with the unit, if you are tech go for a FTA receiver , that is illegal as well. the receiver might have a fault with the LNB power supply, it should provide 19 or 13 volts respectively to the LNB Feed assy for polarity assignment
Jun 10, 2012 | GPS
Even Transponderds Zero
Typically that indicates a bad LNB or connection to the LNB. Try moving the line to one of the other three ports on the LNB and if that doesn't work then you will need to replace it
May 18, 2017 | Directv HR10-250 DTV Receiver
Hello, i have dream box DM 800 HD PVR
Hardware. Check the power source, the 18v is used only for the LNB.
Feb 12, 2010 | RCA DISH Network(r) 311 Satellite System
We have a satellite and wish to connect 1 Sky TV and 3 Freeview receivers. We have installed a 4 way splitter but it will only take 1 sky and 1 freeview. As soon as we plug in another freeview, the power...
No the 2 receiver must be set. The supply going to LNB must switched off letting only one Freeview receiver supply to LNB is "ON". Meaning the one that give supply to LNB is the master receiver if you sw. it OFF the remaining2 can't receive programme.
Jun 07, 2009 | Televison & Video
DTV H20-600
I do not have an schematic for this receiver. This receiver might not use LM317 or TIP42C but a different voltage regulator, try to locate where the 20 volts line from the power supply and follow it to anywhere near the LNB tuner circuitry. This type of IC is normally mounted on a heatsink.
Lastly if you are a subscriber, give you satellite service porvider a call to get a replacement.
Nov 08, 2008 | Philips DIRECTV H20 DTV Receiver
DTV H20-600
You could check the voltages yourself to see if they are low. The horizontal polarity needs about 19 volts and the vertical polarity about 14 volts to work properly. If those voltages are lower by 25%, the receiver might failed to scan and that is when it locks up because is trying to find signal. The other issue could be a defective power supply if the receiver does not work after that 4 hours. There could be some capacitors that lost their dielectric strength causing the drop in voltage.
Let me know if you need further assistance.
Nov 01, 2008 | Philips DIRECTV H20 DTV Receiver
Searching for Satellite
The voltage is supplied by the power-supply through the RF/IF interface usually encased in a metal box on its own. Also without knowing the model number of your unit I cant help any further.
May 16, 2008 | Hughes SDHBH DirecTV DTV Receiver
Directv h20 receiver has low volyage to the lnb.
Good Luck.
Mar 08, 2008 | Philips DIRECTV H20 DTV Receiver
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
