Question about Maytag M7DH65B2A Dehumidifier
ManualMaytag M7DH65B2A - Maytag M7DH65B2A Dehumidifier
Does not start
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier2_bing.gif Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
May 09, 2010 | Maytag M7DH65B2A Dehumidifier
Need a new squirl cage
All the parts that are availble for your unit can be found here: http://www.appliancefactoryparts.com/dehumidifiers/helpcenter/breakdowns/maytag/maytag-m7dh65b2a-a.html
Thanks for using FixYa.
Kelly
Apr 12, 2010 | Maytag M7DH65B2A Dehumidifier
Operating manual for M7DH65B2A
match the model to a sears model - their manuals are on line at searsdirect.com
Jan 05, 2010 | Maytag M7DH65B2A Dehumidifier
How do I connect a drain hose to the maytag M7DH65B2A Dehumidifier, so that It will drain it's self while I'm on holidays
Connect the correct size tubing to the 90 degree drain on the left side of the unit(above water tray) and knock out plastic cutout on the rear of dehumidifier. Feed into drain.
Sep 03, 2009 | Maytag M7DH65B2A Dehumidifier
I have a Maytag M7DH65B2A. I hooked up a hose to
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 20, 2009 | Maytag M7DH65B2A Dehumidifier
Maytag m7dh65b2a freezes up ,
Found the instruction book and by reading the setting it allowed the machine to shut off before it freezes up.
Thank you.
May 28, 2009 | Maytag M7DH65B2A Dehumidifier
M7dh65b2a dehumidifier is icing up
The clip that holds the sensor also rusted out on my M7DH65B2A (Rev-A-R) last year. How to reinstall the sensor with no clip? I used a pair of pliers to crimp/squeeze the sensor a bit. This makes it thin enough so that it could be positioned between a pair of coils, using a pair of pliers. I don't think this has ruined the sensor as the unit generally works well, except when room temperature drops into the low 60's farenheit. Best of luck.
Apr 30, 2009 | Maytag M7DH65B2A Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
63 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
