The blower fan motor of galanz ac has six wires anybody can explain me in details why it has six wires and is is hook up by 3 in the pcb
farfield
  • 462 Answers
SOURCE: RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Posted on Mar 08, 2009
  • 116 Answers
SOURCE: My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
Posted on May 11, 2009
james3751
  • 614 Answers
SOURCE: trying to install a fan motor for my outside ac
Your old moter had three wires. Common High and brown for capacitor. This one sounds like a two speed. Dont worry Now you have two brown wires for you capacitor instead of one. Tape off brown wire with white strip. Connect other brown to cap. You should have a white or yellow for common wire and black for high. Tape of the other extra wire and wire in like the three wire. Rusty
Posted on Jun 07, 2009
  • 358 Answers
SOURCE: wire an AC fan motor
Look at the schematic on the new motor , but i think if the 2 purple wires go each one to each side of the capacitor, the black to line and you need to connect the other line which Im 99% sure is the whte wire which is the only one left.Remember you need 220v between the fan motor lines for it to work.
Posted on Oct 01, 2009
  • 788 Answers
SOURCE: I changed my fan motor and squirl cage blower
If you have changed the motor, I assume that the RPM is the same as the motor you have removed.?
Check the rotation of the new motor, if you have it turning in the wrong direction, it does not matter how fast it turns, it will not send enough air across the evaporator and condenser coils.
Also, if you have changed the motor, you should also change the run capacitor for the power motor.
Hope this info has helped you.
Posted on Oct 08, 2009
Blower motor installation
just check the wiring diagram and connect the two wires for the desired speed and put a wire nut one the third one.
Aug 08, 2014 | Emerson NEW A/C Fan MOTOR 1/4 1/6 1/8 HP,...
Replaced Blower Motor and Resistor.AC works but the Blower Motor relay Keeps melting.
So you need a repair shop or dealer to do the
required testing to find & resolve ALL wiring
& electrical problems
You do not want a guess from an internet site
Doesn't work that way
Need wiring diagrams,lots of your time to explain the
issues & some detailed & possibly lengthy & for you,costly
labor time, to just find the main issue
Jul 16, 2014 | 2001 Dodge Durango
2006 Toyota Tacoma AC Blower works intermittently
there is a TSB for a noisy blower motor and not working except on Hi, both cover under 36K miles, repair includes replacing blower motor and or resistor block and harness, judging your problem can be a bad resistor block and harness. hope it helps
Jul 30, 2012 | 2006 Toyota Tacoma
Mars blower motor diagram?4 wires
Gentlemen,
I have a GE P547BS fan motor. I find replace it with a Mars 10584 fan motor. GE has five wires, BRN, YEL,PUR,BLK,RED. Goes through the capacitor with the yellow going on to 200 V the purple and black go to 220 V. Mars motor as a six wire connection two Brown's go to the capacitor. yellow I'm assuming goes to the hot/neutral and a black I would say would be high-speed blue is medium and red is low. Now when I connect with this way it blows the fuse. Anybody run into this problem before? Any help? By the way, it's a 240 V single phase system.
Jun 05, 2012 | Heating & Cooling
I turned on the ac and the light does not work, the vents are not blowing and the car is running hot. I have a saturn SL 1996
First check the 15 amp HVAC fuse located in the main fuse block inside the car on the passenger side of the center console, under a cover. If the fuse is good, then the problem may either be the HVAC blower switch (which is the fan blower selector switch), the fan blower motor resistor, or the fan blower motor. An auto repair manual will explain and illustrate for you the steps on how to check each of these components.
Even after pushing the ac light switch on, the fan blower selector switch has to be turned on as well (working) because it provides an electrical path to the positive side of the battery to complete the circuit and turn the ac light on. What the ac light switch does is provide the electrical path for the ac compressor clutch to come on through the ac control relay which is controlled by the car's PCM(computer) when you want ac, but the ac light switch still needs to run through the fan blower selector switch to receive its power. You can turn on the fan without the ac light switch because it gets its ground path(negative) from the blower motor. So the blower motor has to work in order to provide a ground path for the fan blower selector switch to be functional. You could have a faulty blower motor which is why no air blows through the vents. The fan blower motor is located inside the car on the passenger side underneath the dash at the bottom end of the glove compartment box. You'll see it. It's right above where a person rests their feet on the floor. Therefore, if your 15 amp HVAC fuse is good, check to see if you have voltage at the blower motor connector. Unclip the connector and with the ignition on and the fan blower switch moved to any one of the first 3 selections, check for voltage using a multimeter. The voltage will vary because there is a blower motor resistor. Voltage should be higher on setting 3 than 1. If you do have voltage at the blower motor connector, check for a faulty blower motor. The auto repair manual will tell you how to do it using jumper wires.
It's normal that your car is running hot because the radiator fan works in conjunction with your ac compressor. If the ac is on, the radiator fan will be on and therefore the engine coolant temperature will stay in it's normal operating range. If the ac is off, the radiator fan will stay off as well and the engine coolant temperature gauge will begin to rise and show pretty hot (especially at idle). It will do this up until a certain degree then the radiator fan should turn on thermostatically and stabilize the temperature. It's scary and I know what your saying because it does that to my car if my ac isn't on. Don't worry it won't overheat.
May 29, 2011 | 1996 Saturn SL
Ac is automaticaly stop and desply message in screen E 3
E-3. Indoor fan motor mechanism locked or no power to blower motor. Check manually by rotating. If rotate freely, check power to motor. If no power PCB defective. Replace it. If hard to rotate motor, replace bearings or motor. Helpful?
Jan 28, 2011 | Samsung Heating & Cooling
Blower suddenly quit working
The recharge of your a/c system and this is unrelated, could be a bad blower motor or blower motor resistor, have you checked your blower motor fuse? If fuse good, check voltage at blower motor, sit under dash on passenger side, just below dash, you will be able to see it, will have two wire's going to it, only one will have voltage with switch on, if you have voltage replace it, not that hard of a job to do, shop repair time to remove and replace blower motor is .7 tenths of an hour, hope this was very helpful.
Jul 07, 2010 | 1998 Volkswagen Beetle
Fan blower motor
The Canyon has an inherint problem with the Fan Power cable being loose. When I say loose...I'm saying that you need to adjust the wires and then take a zip strip to tighten it up.
Passenger side under the dask are 2 cable hook ups. the one on the farthest right (Only 2 wires going to the plug) is the fan power cable. Jiggle it while the fan is on position number3 so you can hear when it comes on!!!
Nov 18, 2008 | 2004 GMC Canyon
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
