Question about Ubi Soft Entertainment Cold Fear for Windows
Cold fear menu change to english - Ubi Soft Entertainment Cold Fear for Windows
How to change language in samsung sph400
The display language is preset to English. To change the language, from the standby screen, press Menu > Settings > Phone Settings > Language. Choose from English, Espa?ol (Spanish), or Chinese for both the screen text and input language. Note: If you accidentally change your language to Espa?ol and need to reset it to English, from the standby screen, press Menu 9 5 2, select English, and press the OK key.
Sep 01, 2015 | Samsung Cell Phones
Change language from german to english on p3015
Hit the Menu button.
Arrow down to the 6th menu option which is Configure device. Hit OK.
Arrow down to the 3rd Option which is System Setup. Hit OK.
Arrow down to the last option. Hit OK and you can change the language to English. Hit OK.
May 15, 2012 | HP P3015 Laser Printer
I changed my sim card to Nokia 2700. Switched on the phone but that's language was changed. How change the language Hindi to English. Menu - settings that i know.
Hi let me give you a hint.First try to Open Menu >> Setting by following the symbol >>Open Phone setting by following the symbol>>> inside the you'll see English.....Good luck
May 02, 2012 | Nokia Classic 2700 Cell Phone
How to change japanese to english language in a nikon d90
Press the MENU button. Press cursor-left, then cursor-up/down to select the wrench icon. Press cursor-right. Use cursor-up/down to select the item that says "Language" in the current language and in English. Press cursor-right. Use cursor-up/down to select "English" and press the OK button. Press MENU to exit the menu.
Apr 03, 2012 | Nikon D90 Body Only Digital Camera
Sony Bravia LED Restore Language settings to english
Press the Menu button and choose setup(The one that looks like a drawer). The langauge option is the first one in the setup sub menu. Select it, change it to English and press OK. Exit the menu. Thats all.
Aug 15, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Fujifilm a230 change language to English (leaving
Press MENU/OK to display the menu. Use up/down to select SET. Press right to display the setup menu. Use left/right to select the wrench with the digit 2 next to it. Press down to enter the menu. The second item on that menu should be Language, so use up/down to select it, then press right to enter. One of the choices should be "English". Highlight it and press MENU/OK.
Jul 09, 2010 | FUJIFILM A170 Digital Camera
Changing language from chines to english for HTC P3450
Would you love a HTC Touch Diamond, but afraid it wont work in your language? Never fear, Panosha from XDA-Developers have the solution.
Simply change the value in this registry key HKEY_CURRENT_USER\MUI\CurLang from Hex 409 (english) to any other localization value (found in this list ). 408 is Greek, 404 is traditional Chinese, 40E is Hungarian and so on.
Tip via XDA-Developers.com
Jun 01, 2010 | HTC Touch Cell Phone (Unlocked) - Soft...
Computer cannot restart and i fear i will lose
Hi there
The delete restoration data indicated the system has gone into hibernate mode. If you had any unsaved Word documents open on the screen before it went into hibernate mode, only the unsaved changes will be lost. The actual documents (if previously saved) will remain saved.
You can safely accept the delete restoration message, and the system will boot as normal and let you login. As long as your current work was saved, it will stay saved.
I hope this helps. Kindly rate my solution if I have been helpful.
Thank you.
Aug 23, 2009 | Samsung NC10-14GW Notebook
I cannot change my Motorola L6i back to English.
1)Go to menu/setting/initial setup/language/chose English press ok.or
2)Menu/setting select/navigation key down 5 times/initial setup press change/pess navi key down 5 times,press change,then select English press change.hope to solve problem.
Aug 16, 2009 | Motorola Mobility L6 Cellular Phone
My phone is set in Italian. How do I change the
My phone is set in Italian. How do I change the language to English?
Jul 06, 2009 | Cell Phones
Ubi Soft Entertainment Cold Fear for Windows Logo
62 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Dan Shibata
Dan Shibata
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
