Question about HP OfficeJet 7110 All-In-One Thermal Printer
Won print excel office - HP OfficeJet 7110 All-In-One Thermal Printer
I can't print an Excel spreadsheet on Office for Mac 2011 on my new HP Office jet 8600 printer. The preview is blank! I have check the HP settings & all is in order,i think. Help!
if your printer is already, click file -> print, then do you hear the voice from printer. if not, your printer is not boot.
and you said your preview is blank. you not load the page with content. I guess you don't have the right to print it.
by the way, if you forgot the office password, visit this site to know how office password recovery
Apr 20, 2013 | HP OfficeJet Office Equipment & Supplies
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
What is the procedure to print ms excel worksheet
Get your Worksheet Copy ready in Microsoft Excel. Go to Option and click on Print (if you are using MS-Office 2010) or Click on Print Preview (if you are using MS-Office 2007) to get a preview of your copy ( i.e. what you are going to print just now). If you want to print it directly, press Ctrl+P to get started with printing your copy and click on Print option (for both Office 2007 & 2010).
Feb 02, 2011 | Microsoft Windows XP Professional for PC
Problem Printing Excel file
You may find it easier to follow the steps if you print this article first. .... Step 4: Remove any remaining 2007 Microsoft Office installation files .... Microsoft Office Standard 2007; Microsoft Office Home and Student 2007; Microsoft Office Basic 2007; Microsoft Office Access 2007; Microsoft Office Excel 2007 ...
support.microsoft.com/kb/928218
Jul 20, 2010 | Microsoft Office Home and Student 2007...
Since upgrading to Windows 7, I can't print from Excel (Office 2003). When I try, a "Print to File" window pops up even though that check box is unchecked in the print window. I can print from Word and...
try to make the installed printers as a default printer and then try to print.
in case that does not work when you try to print from excel, click on the drop down for printer name and select the correct printer.
This should help you
Jul 12, 2010 | Microsoft Excel for PC
Very slow printing on my HP office jet J 3680
you may need to visit the hp website for additional software
Apr 19, 2010 | HP J3680 Officejet All In One Printer
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
It won't print from my word document even though it says it's printing
Dear sir or madam
I have mircosoft office 98 and I can print from excel but not from word. Its not a printer fault as i can print a test page and excel docs.
Tracy
Dec 10, 2009 | Lexmark Z2300 InkJet Printer
Open attached files from e-mails
If all you are wanting to do is read or print the email attachments, and they have been written using Word 2003 or Excel 2003, you can go to Microsoft.com and download Word Viewer 2003 and Excel Viewer 2003. These two viewers will allow you to read or print either Word or Excel documents as long as the original composer used Word 2003 or Excel 2003, or some earlier version such as 2000 or XP. To the best of my knowledge, Microsoft has not released a viewer for any of its 2007 programs yet.
However, if you are wanting to compose new documents, or edit the attached documents, you will need to have a copy of the program in question.
There is also one other possibility. You can go to openoffice.org and download a free copy of Open Office. I am not sure if the Open Office Suite is 100% compatible with the Microsoft Office products, but it should be close enough to get you by.
One other thing, if you are receiving .pdf documents, you can go to Adobe.com and download the latest version of Adobe Reader. This is also a free download and will allow you to open, view and print the .pdf documents but, again, in order to edit them you will need a copy of Adobe Acrobat (not free) or some other compatible program such as Open Office (again there may be some slight compatibility issues to deal with).
Hope that helps - Graye
Nov 25, 2008 | Microsoft Office Professional 2007 Full...
HP OfficeJet 7110 All-In-One Thermal Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
