Question about Mantis 4-Cycle Tiller
How much oil does a honda gx 25 4stroke - Mantis 4-Cycle Tiller
Gx 270 clean carburetor new spark plug .change oil and still wont start Honda GX 270
Check the coil to see if it's working. Sometime too,it could be the carburator though new,but may be the floater valve is stuck and you would have to service it.
Apr 30, 2015 | Honda Vehicle Parts & Accessories
Gx
carburetor float is either bad or sticking.shut fuel off remove fuel bowl 10 mm bolt once removed pull pin out of float and inspect it at the same time re open fuel valve to allow fuel to push any debris the might be still in the port.re install float and test by slightly pushing the float upward and turn fuel on no fuel should drain unless you release the float if float has any fuel inside replace it if not finish putting it together and problem solved:)
Aug 22, 2014 | Honda 11 HP Engine w/electric start - GX...
Needs oil change ; what is correct oil to use ?
Typically they use a 10w30 oil in the engine and a non-detergent SAE30 oil in the pump portion.
May 06, 2014 | Honda Garden
Oil Level Sensor Issues
Not worth the work. Just leave it disconnected and check oil twice daily under hard working conditions. Change the oil every 100 hrs of hard use or when it looks black and dirty.
Apr 09, 2014 | Honda Air Tools & Compressors
I have a Honda GX 160 and I an getting gas in the oil
hi under the carb is a drain bowl .shut the fuel off then take the bowl off 10 mm bolt .then you will see a plastic float hold the float up and turn the fuel on if fuel is cuming out the needle might have dirt on it. turn fuel off now pull the pin out that holds float in place the needle will come down with float spray needle and where needle is seated with carb cleaner now re fit needle and float and hold float up and turn fuel on if no fuel comes out problem sorted. drain oil and fill with new oil.if still leaking fuel you need a new needle
Sep 24, 2013 | Honda Horizontal OHV Engine for Non Pumps ...
Leaf blower turns off
ck oil level ck oil switch the one comes out of block change oil
Dec 14, 2012 | 9 HP 6:1 Gear Ratio GX270 Engine
Oil window broken
we have a honda gx 340 11.0 dont know what type of oil to use.
has 3 different oil type plugs????>
Sep 28, 2010 | Honda Pressure Washer PSI 3000
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
Honda GX 160 quits running at variable times.
a coil wire may be shorting so look for damage on them!
you can sleeve them or a quality electrical tape will be ok for temp measure ok
Cheers Rob.
Jul 28, 2009 | Garden
Mantis 4-Cycle Tiller Logo
75 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
