LG dvd receiver ht353 does not come on, the fuse on the circuit board was burn! then replaced and the new fuse as soon as it was put on blew as well. Please advise
3 Suggested Answers
  • 104 Answers
SOURCE: 1.6A250V fuse blows on V3500 power circuit board
Your DVD combo use a Switch Mode Power supply.
If you want to give it a bash here is a good guide that explains how they work and how to trouble shoot. http://www.repairfaq.org/sam/smpsfaq.htm
but ...
in 95% of the cases it is a shorted switchmode power transistor and other semiconductors, open fusable resistors, other bad parts. Note: actual cause of failure may be power surge/brownout/lightning strikes, random failure, or primary side electrolytic capacitor(s) with greatly reduced capacity or entirely open - test them before powering up the repaired unit.
Posted on Mar 01, 2010
  • 5481 Answers
SOURCE: I lost the Remote Controller to my LG DVD HT353 Receiver while moving home. Don't know its number. Any help can do. Lemmuel_1
I found the HT353 replacement remote available in the UK here: http://www.avuk.com/product_info.php/buy/Original-LG-Remote-Control/model/HT353/products_id/253?osCsid=104768add3e62be2669abc8c5b608fb4 . I also found a remote, AKB36087610 , for the LG HT353SDA0 at http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=AKB36087610 . It's also listed at Encompass Parts: http://www.encompassparts.com/item/8006951/LG_Electronics/AKB36087610/Remote_Controller_Assembly . Remotes.com also lists the AKB36087610 remote: http://remotes.com/remotes/servlet/rs?a=gmi&smodel=AKB36087610&brand_pn=ZENITH_AKB36087610&mode=large&uuid=13446606264530 . Use the picture here to tell if this might be the correct remote.
I hope this helps.
Posted on Aug 11, 2012
Why does the fuse keep blowing on my cub cadet ltx 1050
A fuse blows because the circuit it provide power to has a shorted component or wire.
May 16, 2017 | Cars & Trucks
JD-VD502 DVD player blew a fuse. I replaced it with a 1-amp 250 volt from radio shack but as soon as I powered on, the fuse flashed and blew again. I tried twice, same result. Is there a reason this keeps...
Hello
Never put any fuse in it and switch ON. It has some short with internal circuit, and should be repaired before installing a new fuse. The fuse use is as a protection device to protect the other circuit parts from further damage. If you will put an other fuse, and switch it ON again, you are making things more worse than present. Find out the reason for buring out fuse. If you can do it by yourself. Otherwise get it repaired by any experienced service personal. Never make it irreparable. OK.
May 07, 2011 | Jwin JD-VD502 DVD Player
I have an LG dvd home theater system model no: HT302, plays everything bt no sound. So i've been tring to get to solve the problem bt still nothing comes right, so now i'm looking for pc board for these...
common the capacitors in the switch mode, use quality 105Degree smps caps.
the faulty caps are usually swollen, replace all while you have it open.
Jul 30, 2010 | LG HT302SD Theater System
Burned our fuse in circuit board
it is a 250V 15 amp. clip the fuse off the wire, close, and solider in a new one. Terrible design. LG should have to replace free or be sued !
Feb 23, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
Fuse
If the fuse blew again then there is more than likely a problem with one or more of the boards components. First start by unscrewing the power supply and looking on the underside, you may see some burn marks. If you do then it is likely that the component above the burn marks has blown and needs to be replaced. If you do not see any burn marks then the best place to start is with the diodes on the board. If its still not working, e.g. the fuse blew again then it may be that the problem lies elsewhere on the power supply... Good luck.
Dec 06, 2005 | RCA RS2020 CD Shelf System
Televison & Video Logo
Top Televison & Video Experts
