Question about Wagner Power Products 0154842 Medium Spray Gun Filter, 50 Mesh
Wagner power sprayer does not suck up paint - Wagner Power Products 0154842 Medium Spray Gun Filter, 50 Mesh
3 Suggested Answers
  • 154 Answers
SOURCE: Wagner Power Sprayer will not lift paint from the plastic bottle
pump may be bad on sprayer or gasket on it
Posted on Aug 03, 2009
jyackle5
  • 8197 Answers
SOURCE: I have 2 Wagner power painters, neither work at
I have had that happen to me you need to rebuild the diaphragm to **** up the paint.
Good luck
Posted on Sep 30, 2009
What cain of oil a cant uuse for wagner 1250 hp
Your Wagner 1250 is a diaphragm airless sprayer, which uses hydraulic oil to push the diaphragm, so the oil must be hydraulic quality as it gets quite hot; don't use any other type. The Wagner part number for their quart size is 0088009
Jun 15, 2015 | Wagner SprayTech Wagner Airless Paint...
Will not suck the paint just air is coming out
Hello I just saw this in my inbox, let me see if I can help you-
NOTE: Whenever you are going to spray with any HVLP or cup-gun
strain paint through either a strainer bag or an Automotive strainer cone to remove any kind of debris from the paint that can clog the delivery tube that sucks the paint up from the "cup" and into the fluid needle.
yes even though "Wagner" says the Flexio will spray un-thinned Latex-
However by thinning your paint 10% to 15% you will get better coverage and the paint will move through the gun better
If you have no paint coming out try adjusting the fluid material knob on top-
Also try holding a piece of card in front of the the Tip and try all your Adjustments and you should start seeing the paint spraying onto the piece of cardboard or wall.
Thanks,
Perry Tradesman @ Tradesman Painting & Decorating
Feb 15, 2015 | Wagner SprayTech Paint Sprayer. Flexio 590...
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
Sep 01, 2014 | Wagner Paint Sprayer. Flexio 570 HVLP...
My Wagner paint ready sprayer will not spray paint
I'm sorry to hear that the container is stuck to your sprayer. Besides a bad thread or cross-threading, there isn't really any reason the container would be stuck - unless paint had been left in the gun long enough to cause it to dry. call 1-800-328-8251 and they'll do our best to assist you with this.
As a note, the Control Spray Double Duty is a thin body material sprayer for things like stains, sealers, varnish etc. Not for thick latex materials, which I suspect is what you're applying to the wall and ceiling. Not that this would cause the container to get stuck on the gun, but I wanted to point out that this gun probably isn't the best for the project you are tackling.
Aug 12, 2014 | Wagner Spray Tech PAINT READY SPRAYER
Getting lots of air pressure but no paint comes out
You have old paint that is plugging the pick-up line. you need to clean your sprayer very well each time you use it. I hope this helps you out some.
Jan 12, 2014 | Wagner SprayTech Wagner W665 Wall Perfect...
My sprayer has power and blows air but no paint comes out
you have old paint that is pluging the pick-up line. you need to clean your sprayer very well each time you use it. I hope this helps you out some.
Aug 14, 2013 | Wagner SprayTech Paint Sprayer. Flexio 590...
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
Wagner Power Products 0154842 Medium Spray Gun Filter, 50 Mesh  Logo
105 people viewed this question
Top Wagner Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
 Andy
Andy
Level 1 Expert
Are you a Wagner Air Tool and Compressor Expert? Answer questions, earn points and help others
