TV shuts down
The set will come on, then picture will start pulling in on the right side, then shut down in about 20 minutes. I had a similar problem with it about a year ago and found a service letter saying to replace the 2455 capacitor. I did this and unit has worked fine until now. I thought my solder joint may have come loose, so I resoldered it but no luck. I am a very experienced mechanic but a novice on televisions. Any help would be appreciated.
  • 1 more comment
  • Michael  Lindley
    Michael Lindley Sep 29, 2007
    I thought unit was going into safe mode when it shut down but it may actually be shutting itself off. I have had unit on for over an hour and it has shut off once but came right back on. It will diplay perfectly for a while then it will start pulling in on right side then go back to perfect picture again. It will change channel by itself or pull up adj menu by itself. Someone please take a stab at this problem. The TV guys I have talked to say they no longer repair boards, just replace them. The board cost more than the TV and it's not 4 yrs old yet. Philips 32pt563s37g board prt#313917726261.
  • Michael  Lindley
    Michael Lindley Sep 30, 2007
    While going over the hor ciruit I found a small portion of the printed circuit pulled loose from the board near a capacitor. It came completely off on my solderwick when I took the cap off. Unless there is a simple way to repair the printed circuit I am giving up and junking the set. Thanks for the help. At least you sent me in the right direction.
  • matney5 Nov 04, 2007
    I have a sharp color tv 27u-s50 that is approx 4 yrs old, and now it will be on for about 45-60 minutes and it will automatically shut off and a white spot appeared in the center of the tv. we had it unplugged for a few weeks then tried the set again. It worked for about 45 minutes then did this again. What could it be? i don't want to run out and buy a new set if it is something that i can fix inexpensively.
    thanks
    Problem Solver:
HiWatugot I sent another question re My fridge/icemaker door. I posted it on my message board and was not sure if you'd get it. Thanks Paul
Posted on Oct 06, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is due to horizontal instability in ckt. please replace capacitors in hor, osc section I think it will be ok.
Posted on Sep 29, 2007
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
Tv remains on for about 20 minutes then shuts off by itself and won't come back on. please help
does the power indicator blink when the set shuts down? If so thats an error code let me know the number of blinks and I will assist with the reason why the set is shutting down.
Jan 20, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Tv shutting off then comes on
your lamp is going out, they last around 2 years, on the average, this is easily replaced by you, door is on the right side of the tv, you can take the lamp out, if it has a bubble on it, it is getting ready to go out
Jan 09, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Fujitsu 42" Plasma Display shuts off after 20 minutes
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Oct 21, 2007 | Fujitsu Plasmavision PDS-4233 42 in....
Sony KV 20S40 20" tv flutters, reduces in size and then shuts off
The set most probably has cracked solder joints in one of the deflection circuits, which is pretty common. The picture tube and major components are fine. A good tech can quickly resolder the main board and that should not cost too much. If your set came into my shop I would charge about $50 but ask around, the shops in your area will vary.
Jul 31, 2007 | Sony KV-20S40 20" TV
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
