Question about Cepia One Touch Pistol Motorized Power Sprayer
Need a new nozzel - Cepia One Touch Pistol Motorized Power Sprayer
Why do I have soot in the drum?
inproper combustion, oil air mixture not wright change oil nozzel, sound like it is worn out, if new nozzel open up air band a little more to inject more air
Dec 22, 2015 | Heating & Cooling
I have deep cleaned my MP190 twice as per instructions and still I get horizontal lines in my printing.
The printhead has a few blocked nozzels. If deep cleaning does not clear the blocked nozzels then the printhead needs to be changed.
A new printhead is an expensive item and costs nearly as much as a new printer. I suggest you put your money towards a new and better printer that may be a more cost effective solution.
May 09, 2012 | Canon PIXMA MP190 All-In-One InkJet...
Poulan 18" Wild Thing Chainsaw. replaced bulb,
Ok lets get the pipes conecterd correctly to start with, the hose comeing from the tank with the filter on the end, connects to the carb fuel inlet nozzel ( the nozzel neares to the pump cover held with one screw ) the pipe coming from the other nozzel on the carb goes to the short nozzel on the primer ( suction ) then the pipe from the longest nozzel on the ptimer goes back to the tank, once you have this correct, try the saw again. Change the filter in the tank, the carb screws will have some type of anti tamper device, this is why you only have a small amount of adjustment, you may need to remove these to adjust the carb properly, if there are any splits or cracks in the fuel lines the saw will not run properly.
Mar 05, 2011 | Poulan Garden
I need a fuel line diagram for a mucculloch silvereagle
I have never seen one of these machines, however machines with fuel bulbs all work the same way, the fuel hose in the tank with the filter on the end connects to the fuel inlet nozzel on the carb ( the nozzel nearest to the pump cover afixes with one central screw ) the a hose then connects to the other nozzel on the carb, and afixes to the suction side of the fuel primer ( normally the shorter of the two nozzels on the primer ) another pipe connects to the other nozzel on the primer ( normally the longer of the two, the pressure nozzel ) and the other end is just pushed into the fuel, to return the fuel. Remember, the bulb pulls fuel from the carb, into the bulb, and dumps it back into the fuel tank, this way it cannot flood the engine.
Feb 13, 2011 | McCulloch Garden
AWW - the wiper fluid doesn't squirt out onto the windshield, it just sort of leaks onto the hood :((
are both nozzels doing this? if so open the hood, find the hose that goes to the nozzels and disconnect before the nozzels. if it squirts out good there then mabey the nozzels are clogged. to unclogg try breaking a hair off of a wire brush and using it to rod out the orafice in the nozzel
Nov 03, 2010 | 1997 Toyota Tercel
Error message: remove and check cartridge on
If it's a new cartridge one of two possible problems has occured. 1.) The cartidge is not seated fully in the cartridge tray, or 2. when you removed the protective strip from the cartridge a small piece tore off and is stuck to the cartridge. This is a frequent problem. Uder good lighting check for any small stips of clear tape arounf the cartidge nozzels.
In addition, make certain cartifge is fully inserted in tray and locking mechanism is secure.
It sounds surpisingly simple, but I doubt anyone can say it hasn't happened to them at least once.
If it's an old carteidge the nozzel may be clogged. Remove the cartridge an either clean the nozzells with a moist Q-TIP, or dip the entire nozzel section in warm water for a few seconds. Put cartridge back in printer and print a test page. If you cleaned the nozzel with water you may finf you test page smeared with some water, but this will clear up.
Mar 31, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Winshild pump works but the winshield fluid comes out slowly thru the nozzles
try cleaning them out with a piece of wire, the twist ties you get with freezer bags seem to work well for me, just skin down the paper from them. as well if you disconnect the hose from the nozzels and see if the pressure is there without the nozzel. if not much pressure u will need a new pump
Jan 26, 2010 | 2002 Mercury Sable
Just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Oct 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Water feed tube and nozzel seems to plug
What type of plumbing do you have? Galvanized, copper or pvc?
Dec 15, 2008 | Aprilaire 700 Humidifier
Cepia One Touch Pistol Motorized Power Sprayer Logo
Top Cepia Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Cepia Garden Expert? Answer questions, earn points and help others
