Question about QPS Q-See Video Recorder
Need to reset pass word on qs4474 dvr - QPS Q-See Video Recorder
Can not enter pass word as admin or password after 3attempts just beeps do not know what pass word trying to format DVR this is for floureon h264 this happens in all the menu password settings thanks
Dear Friend,
I always helped other people but no one help me to donate some amount if it helped you please do some donation.
Paypal: www.paypal.me/nitinkhatri
Subscribe My Channel: CCTV Networking Technical Support
Here is the Password Reset Tool for Floureon H264 DVR.
Download: http://milantrend.com/FLOUREON-Modify-Password.rar
Oct 04, 2017 | Home Security
How to reset my pass word on my Samsung Security Video System SDH-B74041
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Samsung Security DVR Reset Procedure #1
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
Samsung Security DVR Reset Procedure #2
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    Press and hold the following buttons
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
    When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
These reset procedures cover many Samsung Security DVRs, but not all. I will add reset procedures to this article as they become available to me. By design, Security DVRs are made to be secure, and not all of them can be reset by the consumer. If you have an urgent need related to your Samsung Security DVR, you should contact Samsung directly at their support page Samsung Support, or by calling: 877-349-3149. For less urgent matters, you can email them directly at Email Samsung Support. Support is available 7 days a week, 9:00 am - 9:00 pm EST.
Jan 08, 2017 | Samsung Home Security
Changed my admin user and password on samsung dvr sde-4101n And forgot password how do I reset it
there is reset button on the main board in dvr you can press it to get default pass
Mar 14, 2016 | Samsung Home Security
How would I reset or figure out the password to my q-see 16 channel DVR, is there a master user name and password?
YOU GONNA HAVE TO SWITCH POWER OFF AND REMOVE THE DVR COVER THEN FIND THE ON BOARD BATTERY REMOVE IT FOR ABOUT 10 SEC THEN PLUG IT , THAT GONNA GET YOU THE DEFAULT PASS
May 13, 2015 | Home Security
How to reset my dvr provision isr 16 ch
open it up and see if there iis a little battery if not try a hard reset
Jul 23, 2014 | Sharp 1/3" Sharp Color Cctv Ccd Ir Outdoor...
I can't find my DVR's password
you may have to check your user manual they may have a default pass word code.
Jun 12, 2014 | LawMate PV-1000 Law Enforcement Grade...
Reset kguard password
this will get you through the front door Please try this temporary password 519070 to login this will let you get to the admin pass word page so that you can change it i found it on cctv.com page but it takes 7 trys to load the cctv page so im going to post it here for safe keeping
Oct 24, 2011 | KWorld Kguard KG-SHA116 Video Surveillance...
How do iI hardware reset factory Multistar dvr h264 beacuse I forgute admin pass.
I forgate my multistar dvr password plz give me any solution
Jan 19, 2011 | Cameras
Dish network VIP722 DVR - cant get sound to pass thru TV
HDMI is digital sound. I don't know why it's not passing through. You could run a set of audio cables to the surround sound. The not a noticable difference in my opinion.
Mar 15, 2009 | Televison & Video
QPS Q-See   Video Recorder Logo
43 people viewed this question
Top QPS Televison & Video Experts
Electro Med Services...
Are you a QPS Televison and Video Expert? Answer questions, earn points and help others
