Question about XO VENTILATION 24 Xob Range Hood
XO Range Hood - motor and lights shut off - XO VENTILATION 24 Xob Range Hood
HJA2540 cooker hood fan not working. Lights work and little red light comes on when switches for fan speeds are pressed so has the fan gone or is it the capacitor? Many thanks Steve
Unless that's a much bigger range hood than I imagine, there won't be any capacitor - the motor will be of a shaded-pole design. If you have a multimeter, you could measure for voltage on the motor wires when the motor should be running - if reasonable voltage is there but the motor isn't spinning, then the motor's dirty or unlubricated or dead. If no reasonable voltage is present, the electronic controller has failed.
Aug 03, 2014 | Kitchen Ranges
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
2. Fan switch
3. Fan motor
Motor shutting off on Aerolator Systems Exhaust hood - runs for a while and shuts off
bad motor replace // if lucky cleaning will correct and if it has oil holes / oilit . other wise replac it .. mm
Dec 04, 2009 | Superior Hoods CS30-4-60 Stainless Steel
Range hood blower motor - rangemaster
I'm not sure if it a regular home range hood but if it is. Check the price of a new one. A regular home range hood cost around $100.00 and a fan motor runs around the same. If it a commercial type is another story. If commercial Heritage Food Service Equipment will have the motor.
Oct 01, 2009 | Kitchen Ranges
Nutone range hood fan motor quit
You can remove it and bench test it by applying 120 volts to the fan leads. Do you know how to do this -- it can be dangerous if not done properly.
You can also use a voltmeter to measure resistance and check continuity of the motor coils.
May 07, 2009 | Broan-NuTone Intermediate Whispaire ...
Ventline Range Hood Fan broken
In my RV, which should be similar, I removed the filter from the hood. With power off, I removed the fan, which was held on with a clip. Removed two screws holding the motor in and took it to a camper supply store. Mobile home supply would have had it, too. You might find the motor on line if you go to the website of the manufacturer or search for parts for that brand.
Mar 19, 2009 | Kitchen Ranges
NEED NEW MOTOR FOR KICTHEN RANGE HOOD BLOWER
hey I am looking for the same thing I think I found one at emotorstore.com it's a cframe motor #k120
Feb 02, 2009 | Marley PJ1257 Heater
Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Jul 23, 2008 | Kitchen Ranges
XO VENTILATION 24 Xob Range Hood Logo
42 people viewed this question
Top XO VENTILATION Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a XO VENTILATION Kitchen Range Expert? Answer questions, earn points and help others
