Question about Bat Caddy 2012 X3r Remote Control Electric Golf Bag Cart/trolley, W/accessories
Golf cart runs in reverse, but will not run in forward., any ideas ?
1988 club car runs in reverse but not forward
If this is a 5 solenoid cart then I would look at the forward/reverse switch. Sometimes one of the copper contacts will get hot and melt the plastic around it, causing it to sink in and not make contact. I have seen this happen where the cart will move one way and not the other. Other times the contact is so burned, it will not make contact either direction. If the contact is burned then the only cure is a new f/r switch.
Sep 12, 2016 | Golf
Need wiring diagram for forward reverse switch for a 1995 club car golf cart not finding diagram where i am suppose to look,
Finding a free service manual for that golf cart might be difficult. You just might have to bite the bullet and buy one.
Jul 29, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Club Car cart will not move forward---works fine in reverse
check the forward/reverse switch. Possibly a loose wire. Unhook the battery and go to each wire and verify it is connected properly. Then reconnect the battery.
Aug 15, 2015 | Golf
EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Apr 09, 2010 | 1993 Acura Vigor
Club Cart Golf Cart Reverse only
You don't have it connected right. The DC motor is 'polarity reversed' to change direction. That's what the controller does is reverse the polarity to the motor to change direction. If the motor is still working in reverse, then the controller is 'probably' okay. Recheck the connections you made.
Sep 03, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Ez-go golf cart press accelerator pedal and nothing happens
The first thing I would do is lift the seat and check the battery connections. Those batteries are notorious for corrosion at the terminals. Make sure every connection is clean and solid, as in no loose, corroded or frayed battery cables. Next, if the batteries check out, toggle the run/tow switch, also under the seat to make sure it is fully engaged into the run position, and finally check the forward/reverse lever to make sure the connections are clean and tight.
Aug 03, 2009 | Sport & Outdoor - Others
Bat Caddy 2012 X3r Remote Control Electric Golf Bag Cart/trolley, W/accessories Logo
51 people viewed this question
Top Bat Caddy Photography Experts
Tony
Are you a Bat Caddy Photography Expert? Answer questions, earn points and help others
