Question about Electrical Supplies
Nikota generator GSa-M12B
What is the amperage of the 240 plug
3 Suggested Answers
  • 52 Answers
SOURCE: Onan 6500 male 120/240 plug
Northern Tool has a hundred plugs/recepticles. you need to know the amps and volts. just match them to the pictures. or email them a pic of what you need. they helped 3 of my customers with the issue. hope that helps...good luck...
Posted on Aug 30, 2009
SOURCE: i have a nikota 3500, 6.5 hp generator where can i
caall cummins crosspoint 304-769-1012
Posted on Aug 31, 2010
Greetings: I have a 3500 wts 6.5 Nikota generator, turn on and off several seconds. The carburetor is fine, ignition, too. The shoot off well, I would like to give me an idea that can be
you saying it wont keep running
you have spark at the new spark plug
fuel is fresh and uncontaminated
could be
the coil or the plug lead
ok when cool ... fails when hot
the Governor setting
carby jet blockage
if a four stroke a valve adjustment might help
Oct 12, 2016 | Electrical Supplies
I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can check.
All Power America APG3535CN, 2800 Running Watts/3500 ...
www.amazon.com/...Power...Generator/.../B000U0OJ...
Amazon.com, Inc.I then call All Power and am told to give them one more day to get this worked out ....There is no styrofoam enclosure or crate to protect it, the generator is simply ...
NIKOTA 3500 WATT GENERATOR - YouTube
? 0:58
https://www.youtube.com/watch?v=NEeu9Y-0_KM
Aug 27, 2011 - Uploaded by mamasboypowersports
NIKOTA 3500 WATT GENERATOR. ... Diagnosing A GeneratorThat Has No Power Output. - Duration: 3:03. TheDIYGuyDOTnet 117,263 views.
I have a nikota 3500 watt generator and I am not getting any ...
www.fixya.com/support/t26062098-nikota_3500_watt_generator_am_not
2 hours ago - I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can ...
Generator outputs low variable voltage, ideas for troubleshooting ...
www.smokstak.com > ... > Generators & Motors General Discussion
Jan 20, 2016 | Electrical Supplies
My Nikota 3500 watt 6.5hp OHV Engine Electric Generator all of a sudden quit running. I am getting gas and fire to the plug,but it wont start. I am lost and need help.
replace the gas with fresh and treat it with Startron additive to fight against the ethanol in gas and keep it fresh. gas goes bad in a bout a month if not treated now. you might have to take the carb bowl off and clean the carb. good luck hope this helps
Feb 23, 2015 | Electrical Supplies
Nikota 06041
1/4" gas line can be bought at any Auto Parts place. Any generic shutoff can be bought there too.
Dec 09, 2013 | Electrical Supplies
I have generator kipor kde19sta3 when we start then generator after 1 or 2 minutes generator will automatically off and show the fault p 03 so plzzz tell me about p 03 fault thankx
Sounds like an overload on the board. Be sure you're not drawing more amperage out of the plugs on the front of the unit than is listed (typically 12.5 or 20 amps is the limit). If you try and draw more or a surge on the appliance happens during startup, you may end up having to use the 240 volt plug and direct that into a distribution panel to get the 110v unhindered by the plug limitations.
Sep 23, 2013 | Electrical Supplies
I have a briggs and stratton 8500/5500 generator which I am using to power an air conditioner on a camper trailer. I just recently started having a problem where the one circuit breaker keeps tripping when...
Hello, First figure out what the load per leg is on your generator. Are you using the 240 Volts because this is two 120 AC volts legs and they are 120 degrees out of phase with each other.
You will need to figure what the power factor is for each phase on this generator. To figure the power/wattage by using ohm's law. Voltage times Current will give you Watts. Example: If the generator is generator 240 volts the maximum current available is about 23 amps. The maximum current for 120 volts will 46 amps. Therefore, the maximum current per 120 volt circuit is 23 amps for one circuit and 23 amps for the second 120 circuit..
I would try replacing the circuit breaker with the same amperage breaker. Also, watch what the generator load is per circuit. You can install current meter for each circuit. This will give a good indication of which circuit is pulling more load than the other circuit. GB...stewbison
Sep 06, 2011 | Briggs & Stratton Power Products 5,550...
For these 4 control wires. How many watts do they consume. I have a generator 150ft away from the transfer switch, should these 4 18AWG control wires upsized?
No. They are fine. The voltage is 220. But the amperage is nearly nothing because its just for signaling the generator and switch when the powers out. I install, repair, and service generac products for a living.
Feb 10, 2011 | Generac 100 Amp 120/240-Volt Transfer...
Can my 1/2 hp Jacuzzi water pump 240v be run on a generator
If your generator puts out 240 volts and has the amperage to handle the pump load, I believe it can. Your generator installer could answer that.
Dec 04, 2010 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Can I make 2 plug in sockets from one in a 240 volt circuit
There should be NO problem in actually "Adding: another :Outlet" have you thought of a 20 - 25 Amp Power Strip, Multiway Socket, As long as you DO NOT exceed the Amperage/Wattage of the "Supply" The generator, 5000W, there will be no trouble. You MUST ensure however that this is so.
5000 Watts is 21 Amps, Watts = Amps X Volts. IE: 21Amps x 240 Volts = 5000Watts +/- 10%. So the TOTAL Amps drawn by the SUM of all the things connected must be LOWER than,say 20 AMPS.
Feb 22, 2010 | Coleman Powermate Powermate 5000W...
I have a Nikota electric generator 3500 watt 6.5 h.p. ohv - I need a part for the carburator base, where i find this parts?
I also have a NIkota 3500 generator, which had a carberator problem. I just ordered a new carb from Yilong-motor.com in China. They may be able to help you. RJL
Aug 20, 2009 | Coleman Electrical Supplies
Electrical Supplies Logo
19 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
