Question about Beko Washing Machines
Beko WME 7267 W Motor won't turn drum or spin. Belt is o.k.
2 Suggested Answers
vladmototole
  • 226 Answers
SOURCE: beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
Posted on Feb 23, 2012
BEKO WM5120W filling with water program clicking water draining but the drum does not turn belt is ok and pump
DOES IT AGITATE? SOUNDS LIKE A BAD MOTOR COUPLER OR DOOR SWITCH, ALSO A BAD WATER PRESSURE SWITCH WILL NOT ALLOW IT TO GO INTO WASH, HENCE NO SPIN OR WASH CYCLE? SOME MACHINES HAVE A BELT SAFTY SWITCH ON THE MOTOR, THAT MAY GO BAD AT TIMES ALSO AND SHUTS OFF ALL ACTIVITY
Sep 26, 2014 | Washing Machines
Dryer won't spin
Was the belt shredded ( normal wear & tear ) or burnt through which could be a drum bearing or support problem .What does the drum feel like when you turn it by hand is it grinding & lump ? The fact that the motor runs with no load could by the start device faulty these are reasonably cheap to replace this is the small cylinder attached to the side of the motor with two wire connections . if your motor has not got one of these then its the start windings in the motor
Jan 11, 2013 | Maytag Dryers
Beko washing machine WME 7267 fills with water but will not continue through the cycle
Feb 23, 2012 | Beko Washing Machines
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
Beko washing machine drum isn't turning is this an expensive repair? the spin was making more noise than usual before it stopped working
Could be the main bearings have failed, and the belt has come off, remove the rear panel and check the belt is o/k, if it is, then could be motor or control timer/board is faulty.
Jan 30, 2010 | Washing Machines
DRUM NOT TURNING ON BEKO TUMBLE DRYER. JUST OUT OF WARRANTY.
Check your drum belt, sometimes this belt is broken or slipped off the motor pulley or idler arm pulley.
Also could be a faulty motor..
Another thing to try is to turn the drum by reaching inside of the drum and turning it by hand 1/4-1/2 turn with the dryer off. Then turn the dryer on again and see if it works.
Motors will sometimes get a dead zone in them and this help move it from the dead zone.
Sep 26, 2009 | Dryers
Washing Machines Logo
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
