Question about Ricoh Aficio 1035 Copier
My ricoh machine shows functional problem code sc322, how can i repair it?
bowdo
  • 78 Answers
SOURCE: Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Posted on Mar 19, 2008
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
Joed911
  • 4338 Answers
SOURCE: i need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 19, 2009
SOURCE: sc322
For the care of its machine it tries to use to toner of good quality if he is possible original. Toner of low quality produces infinity of problems in its machine. One of them is that it damages the laser unit. Faults in the feeding of paper, among others.
The laser can be clean but, It must do it somebody specialized.
Posted on Aug 31, 2009
  • 22 Answers
SOURCE: 1035 ricoh aficio printer with error code 322
Yes, the code is caused by toner getting into the laser unit. The laser unit likely only needs to be cleaned out. To do so, turn the machine of with the red rocker switch on left side of the machine. You will need to remove the front cover and the brown cover behind it. The mechanical counter is plugged into the brown cover so be careful not to damage the wires. The laser unit is the black plastic case you will see behind the brown cover. Be sure to remove the necessary screws and connectors. Be extra careful of the ribbon cable, it kinks easily and the contacts are easily damaged. The Laser unit will slide out, and you can remove the screws holding the top cover on. After removal, clean the interior of the case and mirrors. Do not use any liquid to clean it, preferrabley canned air and a lint free cloth. After cleaning, reassemble, turn the machine back on, and test.
Posted on Nov 19, 2009
Ricoh afficio 1600ml error code sc322
laser code could be laser unit or board problem that lser unit plugs into.
Feb 01, 2017 | Ricoh Aficio Office Equipment & Supplies
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Sc322
That error codes indicates that the laser unit has failed and will probably need to be replaced. You will need a service tech to do this repair, I do not know the current cost of that part.
Feb 17, 2011 | Ricoh Aficio 450 Copier
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
Feb 09, 2010 | Ricoh Aficio 350e Printer
I need solution to aficio 200 error code sc322
Possible causes:
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Feb 10, 2009 | Ricoh Aficio AP2600 Laser Printer
Sc322
1st laser synchronization error.  It is an expensive part to replace and in most cases its cheaper to by a used Ricoh.  There are some 1035s and 2035s out there that run around $700 in American dollars.  If you can find them.
It's possible there could be something going on with the power supply.
The toner spill can vacuumed as well as the optics and the rest of the machine can be cleaned simply with cleaner.
Nov 01, 2008 | Ricoh Aficio 1035 Copier
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1035 Copier Logo
26 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
