Sharp LC-60LE636E TV has power but won't switch on?
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
Posted on Nov 06, 2009
budmrtn
  • 11361 Answers
SOURCE: Power supply in my Sharp
The common failure in the power supply is due to cheap low quality capacitors, the replacement that was install probably has the same quality cap. I only use good cap from PANASONIC for my repair works.
The moudle is easy to replace, just remove the TV stand, all the back screws, and may be 4~6 screws for the power supply, it uses connectors so yoiu can easily remove them, just take good pictures before working on it so you will know how it goes back together.
You can try getting the module from www.shopjimmy.com, he is my main supplier for boards.
Just make sure to get the number as printed on the sticker of the power supply to get exact match, you can also contact him if you are not sure.
Here is the service manual: http://elektrotanya.com/sharp_lc-32_37d43u.pdf/download.html
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series
Posted on Jun 14, 2011
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
My tv won't come on the green power light just flashes?
push and hold the power button, i did yhat to mine and it now works,also if it comes on reset the tv
Dec 12, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
Tv won't turn on green light blinks
First check the power supply for incorrect voltages, and bad capacitors in an around the output side of the power supply. You may have swollen caps inthe power supply area that needs replacing.
Aug 24, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
My Sharp Aquos LCD TV LC-40C37U will not power up. The green power lamp at the bottom right is blinking. We had a power surge last night, I even measured 180V on the power outlet. Is my TV now damaged?
Good day sir/maam, chances are, yes or no, yes, the surge do has the ability to damage your TV, but no, modern TVs are autovolt (it can work from 90v-240v) so check the manual or back panel to confirm. The most deadly part of the surge is it can hit more than 500v at a split of a second, damaging your TV's switching power supply. The TV's power supply is bad. it cannot produce the proper voltage to power your TV. thats why its on standby. Bring it to your dealer for proper advice on the status of your TV.
Oct 12, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Aug 17, 2009 | Sharp LC-26D4U 26 in. LCD Television
Sharp lc-22sv6u won,t power on. no green light.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
