Question about Kenmore Whirlpool Dryer Timer Model M480 3396215A
Wont start
2 Suggested Answers
  • 2333 Answers
SOURCE: Dryer wont run, lights work, timer clicks
what is the model number?there are a couple of things you can check with the little info you sent,check the door switch,push the paddle in and out ,if it doesn't click it's bad,check to see if the belt broke,on some dryers there is a switch down near the pulley,if the belt brakes the dryer won't run,one more thing if your dryer hasn't had a clean out in a long time or if your clothes have been taking a long time to dry check the thermal fuse located on top of the blower wheel housing,if the lint filter is on top the fuse is in the back,take off the vent line,remove the back panel and check the fuse located to the right and down near the bottom of the duct that the lint filter slides into,if the filter is inside then the fuse is in the front the fuse is on top and to the right of the blower wheel housing,also you should clean out the duct that the filter slides into,blow out the vent line,check outside and make sure the flapper is not blocked with anything and vac out the inside of the dryer where the motor is,you need to do this once a year anyway,if you still need help send the model number and let me know what you find,unplug the dryer to clean it and when working on it and remove one of the wires when using your meter
Posted on Mar 17, 2010
Changed timer/whirlpool model leq9508kq1/dryer runs in accudry mode, wont shut off,what is wrong?
if it wont shut off this is a timer problem contacts fused closed,are you sure this is a new timer?(some are remanufactured)
Feb 12, 2013 | Whirlpool GEW9250 Electric Dryer
Our Whirlpool gas dryer, Model # LDI5701W1 stopped working in the middle of a cycle. Power supply is fine. With door closed, I can't hear the timer humming. Could it be a door switch, timer,?
it maybe but here is a website that shows how to test them, it may be a loose or broken wire, a reset button on the motor, or other things:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 24, 2010 | Kenmore 72622 Gas Dryer
My whirlpool dryer (model LER7646DQO) wont start when the button is pushed; additionally the timer does not continue to run when the dry with the dryrt off
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool thin twin dryer just beeps and wont start
Does this dryer have a dial timer you set, or does it have a keypad? If it has a timer then you have a bad timer. If it has keypads, then you have bad ciruit board
Mar 10, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Model ler8857eqo wont start has powr timer makes clicking sound when timer is turned off start button clicks back out
you nead the unplug the dryer and pull the dryer away from the wall to get to the back panal.next remove the vent hosefrom the dryer.next remove the back panal and the power cord cover.if you look down and to the left you will see a white plastic thermal fuse.remove the wires from the fuse and check that it is closed.if it is open the replace the fuse and reassemble dryer.
Jan 19, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore Whirlpool Dryer Timer Model M480 3396215A Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
