Question about Life Fitness 9500hr Next Generation next Gen Commercial Treadmill Refurbished
Life fitness 9500hr treadmill belt not moving and speed sensor error comes up on the screen
    Top Expert:
  • Life Fitness Master
  • 12,223 Answers
See the video and lube to the rollers bearing front+back .
and Run the calibration software for easy diagnostic for s. sensor
God bless you
Posted on Oct 17, 2013
3 Suggested Answers
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 11 Answers
SOURCE: heart rate monitor chest band not working with Life Fitness 9500H
Enter the diagnostic menu and ensure the "telemetry" option is enabled in the managers config menu.
Posted on Apr 27, 2010
Speed Stall error
Have to check the speed sensor. Either the speed sensor is faulty or the can be dust or speed sensor alignment.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 12, 2013 | Life Fitness F1 Smart Treadmill
Maximum speed is reduced!!
Dear Sir:
Please adjust the sensor speed see the diagram below.
After you must run the software calibration for easy diagnose and troubleshooting.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 08, 2012 | Life Fitness 9500HR Treadmill Next...
9500hr treadmill said "notify maintenance
Your treadmill is notifying you that some maintenance operation has to be performed.
Nov 21, 2017 | Life Fitness 9500HR Treadmill Next...
Treadmill stop then display an error speed
If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
May 21, 2010 | Life Fitness 9500HR Next Generation...
Hi have life fitness 9500hr.when i opne MOTER
Every time I have gotten this message, I have had to replace the motor controller.
Feb 27, 2010 | Life Fitness 9500HR Next Generation...
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Hi! i have a life fitness 9500HR treadmill and it says incline error on the screen! and the incline doesn't work?? can i fix it somehow?
Unplug the treadmill . Remove front cover. On the right hand side if you are facing the front - in the siderail is a white switch that tells the treadmill it is all the way down. Check that it is in place and clean.
If you plug the treadmill in.{Do not touch any thing in the motor compartment} When you press start it should go all the way down [home] to contact the switch. You can also see the lit motor turn at this time before the belt will move it must be all the way down.
Feb 07, 2010 | Life Fitness 9500HR Next Generation...
Life Fitness 9500hr Next Generation next Gen Commercial Treadmill Refurbished Logo
133 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
