Question about Marantz SR-5400 Receiver
Standby light mode
Cannot activate remotely
Standby light blinking
Posted on Jan 29, 2014
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Wont turn on red blinking light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 19, 2013 | NEC PlasmaSync 42MP4 42 in. Television
My modem keeps going to standby mode
That is usually a problem with signal levels or the modem isn't set properlly. I don't know who your provider is but you should get hold of them and get them to fix it. They should send a tech out to check your signal. While they can check the modem remotely it does not provide them with the same information that a onsite check does. There is nothing you can check or change as a end user.
This can be signal levels, or signal quality (noise), or bad cableing and so on.
Apr 16, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
The "on" light is always green, even if turned off. Why?
It occurs when your wii in the Standby, but WiiConnect24 is enabled with Standby Connection is enabled. the content can also be received when the Wii is left in standby mode.
WiiConnect24 can be turned on or off via the setup setting. While the console is in standby, the power LED indicates the current status of the standby connection,
  • Red indicating Standby - wiiConnect is off,
  • Yellow indicating Standby - Connect mode is on. If you hold the power button for 3-4 seconds, the Wii goes into standby mode with Standby Connect off. and WiiConnect24 will not operate until the console is turned on.
  • Green ...
Jan 18, 2010 | Nintendo Wii Console
Remote no longer puts TV in standby
I found an original replacement remote for a Loewe ARC332PB at remotes.com
Sep 30, 2009 | Loewe CAL232 TV
My Windchaser fan model FTR184 does not work anymore - it did yesterday. The oscillator function still works but the fan doesn't come on. The red light indicating standby mode is lit. How do I get it out...
I have a Windchaser fan mode FTR184 also and it is in the same indicator STANDBY mode and now it will not come on and we have the remote, how do you fix this?
Jun 27, 2009 | Windchaser FTR163 SensorFan Stand...
Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Apr 11, 2009 | Televison & Video
NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
Dec 10, 2008 | NEC LT 240K Multimedia Projector
My modem is off
Modem and coaxial cable abnormally connect, or probably loosing power from internet. ask your local ISP
Jun 24, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
MDS-JE 520
what the problem sounds like is that your power button on ur main deck is broken or its in a standby mode activated by the remote. like some new dvd players that have the click in power button on the front u can turn them off by remote saving having to turn on the whole unit again from the main to use it.
Oct 04, 2007 | Sony MDS-JE520 Mini Disc Player
Marantz SR-5400 Receiver Logo
105 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
