Question about Life Fitness Exercise & Fitness
Speed sensor error appears in the screen at start up and the belt doesn't move
    Top Expert:
  • Life Fitness Master
  • 12,223 Answers
speed sensor error appears in the screen at start - 1d2675cf-e1a8-4877-b5f9-c3ade6debdfc.gifSee the video attached. lube the rollers bearing too front+back
However RuN THE software calibration for easy diagnostic and fix it. see the diagram attached for s.sensor.
God bless you
Posted on Oct 17, 2013
3 Suggested Answers
SOURCE: bodyguard t300 treadmill. belt will not turn
Smashed harness created short.
Posted on Jan 27, 2009
ercupa190
  • 12223 Answers
SOURCE: my nordic track treadmill 8600 has controller error08 and belt does not move
Dear Sir:
Please run the software calibration that coming with your equipment, see the instructin under the Hood motor, and follow the steps. or user manuals.This will guide your for diagnose and troubleshooting.
See the attached block diagram for troubleshooting and diagnose that I did prepare for customers.sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 15, 2012
What is E-1 error in Sportsart Tradmills
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Jun 23, 2014 | Sportsart Treadmill Doctor Walking Belt...
Speed Stall error
Have to check the speed sensor. Either the speed sensor is faulty or the can be dust or speed sensor alignment.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 12, 2013 | Life Fitness F1 Smart Treadmill
Belt stopped and showed message ERR22
Precor Error Code 22 Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Dec 06, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
Motor not going on York Optimum 60100 - after a while E 1 appears
Dear Sir:
This is probably a 1) faulty speed sensor or 2)the speed sensor is not plugged in properly. Its also possibly a 3) faulty motor control board or lower board 4) Main motor faulty. . The error codes will differ between makes and models but could be e1.You must test
see my personal TIPS for diagnose and troubleshooting.
See if you can run the software calibration for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
Mar 05, 2012 | York Exercise & Fitness
Carol lewis mot566 error code 03
1)probably a faulty speed sensor
2) speed sensor is not plugged in properly.
3)possibly a faulty motor
4) Main control board or lower board.
Check this video for speed sensor.
http://www.youtube.com/watch?v=23ZgWaVEQjA
adjust the speed sensor:Move the motor to slacken the pulley, then lift the motor to get underneath. That is where the treadmills speed sensor will be located. It is usually a square or rectangular shaped green module with connectors at both ends.
Finally after you did the adjustment you can conclude:
A) Faulty Speed sensor B) Main Motor faulty C) Main Motor Controller faulty.
attached block diagram for treadmill that I did for any treadmills,see how the Main Motor Board has function for 90% of the treadmills.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Nov 23, 2011 | Exercise & Fitness
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
Landice 8 over speed protection
first screen shows any error number? for what you describe I think it is simply speed sensor, try to check the cables leading to the sensor card. and then checks whether the sensor is aligned correctly.
Check speed sensor alignment.
It should be within 1/16" of the flywheel
and parallel to the flywheel.
Is it out of position?
Feb 02, 2010 | Landice L8 LTD Cardio Trainer Treadmill
What does error 1 mean shows in incline window. happens at start, belt doesnt start after countdown?
error 1 simply means no belt movement generally. If belt moves a little it could be the speed sensor but generally it's the motor controller.
Nov 16, 2009 | Endurance TF3i Folding Treadmill
Bowflex treadmill code 05
tHIS MAY BE A SPEED LOSS ERROR. Is the belt moving when this happens? Decribe what lead to this problem in the first place that will help me to better assist you.
Mar 30, 2009 | Bowflex Treadmill Series 7
Open Questions:
Exercise & Fitness Logo
124 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
