Question about Landa PUMP TT1513G 3.4/2200 - 8.702-726.0
Landa Mod. # PG4-25321, lost pressure. Not belts, water supply or strainer, but I notice a small drip on underside of pump body, seems to originate around head mating suirface...may or may not have relevance. Thanks!
I have a Rancilio Silvia around 5 years old. After around a year, it stopped reliably producing dry steam. I have very hard water, but despite regular vinegar cleaning, cannot seem to get it to steam
I work on industrial machines have done so for 15yrs
if your machine is anything like the prof rigs in terms of engineered design then what you are noticing is the pressure release valve working-letting any unused and pressure + water drain from the group head to a small plastic black box below the stainless housing panels/drip tray after extraction is complete.
What i describe should only happen after the shot stopped.
you should hear it and see it the water for about 2seconds after you stop the extraction manually/automatically
Dec 30, 2013 | Rancilio Silvia Espresso Machine
Ariston afa 370x leaking water after wash cycle puddle on floor. no problem with anything else
Hello.
When you are doing your laundry and you notice water on the floor that should not be there. A moderately handy homeowner will be able to identify and fix many kinds of leaks. Doing the service your self can save you the cost and hassle of having a service technician come out. Small leaks lead to large ones quickly, and that can result in ruined flooring and the possibility of mold growth. Fix most leaks in a day or less, with purchased parts from supply houses or home improvement stores.
Here are Instructions and tools Needed to solve the problem
  • Flashlight ,Adjustable wrench ,Flathead and Philips screwdrivers
1. Water Supply Leaks
1 Find the source of the leak. Turn on the machine while it is empty, and then look behind it with a flashlight while the tub is filling. Pay close attention to the hoses, and look for drips or running water. Some drips may start out slow, but gain momentum with continued water pressure.
2 Turn the water off. Often, if the water is leaking from the fitting where the hose attaches to the tap in the wall, you need to replace the hose gaskets. Unscrew the hose from the tap by hand or by using an adjustable wrench. Use a flathead screwdriver to pry the old gasket out. Place a new gasket in the hose connection where the old one was removed.
3 Turn the water on, and check for leaks again. If a leak is at the fitting or elsewhere on the hose itself, replace the entire hose and gasket assembly. Turn the water on again, and check for leaks. If the machine still leaks, check your work, and then look for other causes.
2. Pump Replacement 1Move the dial to the end of the wash cycle to drain the water from the tub. Turn the water off at the wall supply taps.
2 Remove the top of the washer. In many models, the top pops up when you apply upward pressure to the front of the washer at the joint. Sometimes, you may have to remove part of the instrument panel, which is attached with screws.
3 Look into the cabinet around the tub to find the pump. Pumps are either direct-drive or belt-driven. If you see a belt, you have a belt-driven pump. If there is no belt, it is a direct-drive pump. Remove water lines, and take out the old pump. Replace with a new pump, reattach water lines, and reattach the belt, if necessary. Turn on the water, and check for leaks.
Good Luck and thanks for using fixya.
Aug 02, 2011 | Dishwashers
When chemical injector is attached, it works fine. When I put one of the power tips on, I do not get any pressure.
When using the chemical injector your machine is only having to operate under low pressure. This means that your pump only has to transfer water and does not have to compress it. When you insert a pressure nozzle you cause the pump to have resistance and therefore it has to compress the water to make pressure. If you pump seals or valves are worn the pump cannot build this pressure. You need to either rebuild your pump yourself or have it looked at by a service center. If you have any other questions or need parts or service please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Sep 23, 2010 | Honda Landa PG 3500 PSI Pressure Washer
II lost High Pressure while washing I laid the gun down the time cut it off aand I reseted it and had no high pressure I removed the pressure adjuster and noticed it was rusted I cleaned it and replaced it...
The pressure adjuster you are talking about is actually your unloader which is a pressure relief valve. It is normal for this to pop up and down as it moves in and out of bypass mode. Your pressure issue could be a failed unloader, valves or packings in the pump. You will need to bypass your unloader valve to find if the issue lies in the pump or if it is simply a failed unloader. If you have any questions, need parts or service, please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Aug 17, 2010 | Honda Landa PG 3500 PSI Pressure Washer
Maytag Mod. MDB4050AWW
Check inlet water flow. Clean the strainer located near the hose end on the machine.
Check the water pump and it's electrical connections.
May 27, 2010 | Dishwashers
Pressure is very low, what is wrong
Very Vague question as far as problems go, I'll try to narrow down.
If the pressure is low on the tank that is a good thing.
If the pressure of the water going back into the pool from the discharge is low/ weak.. it's not.
If the Pump is operating properly, the problem could be the following
1. Extra long filter hoses. Any hose longer then 6ft will decrease the pressure back to the pool.
2. Chlorinater, salt generator or mineral cartridges in line from the filter to the pool may decrease return pressure, as will solar panels.
3. A filter in need of back washing. An older DE or Cartridge filter may need an acid bath. May also be an issue with newer filters that had to battle a bad algae problem. An Acid bath will remove dead algae from the inside of the grids or tubes/ fingers.
4. If you notice bubbles in the water returning into the pool from the eyeball/discharge, or water in the strainer basket is visibly swirling (bubbles visible) odds are you need you replace the o-ring on the lid of the strainer basket in the front of the pump. This basket may also be clogged with debris, which also effect pressure. Could also be a cracked or warped strainer lid. Should be easy to see when you remove to check o-ring.
Jul 14, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Fan loose , anti-freeze dripping
there is a weap hole in the bottom of the pump if it is leaking from that it is the pump they will make noise when they go out also
Apr 24, 2009 | 1999 Dodge Durango
Landa PUMP TT1513G 3.4/2200 - 8.702-726.0 Logo
64 people viewed this question
Top Landa Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Landa Garden Expert? Answer questions, earn points and help others
