Question about Jeep Lantern
What batteries for remote for jeep lantern - Jeep Lantern
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours http://www.coleman.com/Parts/100/parts-lanterns/5317-702/remote-control-pack-away-family-size-lantern# then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
Tip
SAFETY 1. HANDLE WITH CARE AND AVOID CONTACT WITH CORROSIVE LIQUIDS. 2. AVOID...
SAFETY
2. AVOID LEAVING YOUR UNIT IN DIRECT SUNLIGHT OR IN HOT, HUMID OR DUSTY PL.ACFS
3. KEEP YOUR UNIT AWAY FROM HEATING APPLIANCES AND SOURCES OF ELECTRICAL NOISE SUCH AS FLUORESCENT LAMPS OR MOTORS.
4. ALWAYS TURN YOUR RADIO OR LANTERN OFF WHEN NOT IN USE AND REMOVE BATTERIES IF YOUR UNIT IS NOT GOING TO BE USED FOR LONG PERIOD.
5. OLD BATTERIES CAN LEAK AND CAUSE CORROSION DAMAGING YOUR UNIT.
6. LAMP BULBS OR LANTERN SHOULD ONLY BE REPLACED BY QUALIFIED TECHNICIAN.
NOTE: OUTPUT POWER: FM-550 mw,
AM-405mw
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
My mom purchased this Jeep lantern and does not have the manual that came with it. I don't know how to get the light to stay on. She uses this to get across the street to get her mail. She is an 82 ye
Hi, I'm having a similar issue with my jeep lantern as well. It's actually a really nice lantern, however, when I plug it in with the power cord, it seems like it is A LOT brighter than when it's just running on batteries alone. When using the turn button, it does get brighter and dimmer, just not to the extent I would like it to be as I use the lantern at night as well to do things such as checking the mail and going to my vehicle. I feel much safer with the light at night, but obviously can't keep it plugged in when walking around my property. It just is not as bright running on just the batteries. I'm not sure if there is a mechanical error with the product, but I've never noticed the difference between the brightness until recently. I changed the batteries and it just didn't make a difference. Just wanting to get some advice to see what I could do to try and make the light brighter. Maybe it has to do with the new batteries I bought, however, they are GREAT batteries I purchased and I don't think that is the issue. Some suggestions would be helpful. :)
Nov 16, 2013 | Jeep Lantern
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
Tip
Parts Callout
INSTRUCTION MANUAL PARTS LOCATOR
1. ANTENNA
2. BATTERY COMPARTMENT
3. CARRYING HANDLE
4. COMPASS
5. SPEAKER
6. LCD CLOCK DISPLAY
7. BACK LIGHT (CLOCK)
8. MODE
9. SET
10. FLASHLIGHT
11. LANTERN / FLASHLIGHT / OFF
12. BLINKER I SIREN / OFF
13. WEATHER BAND/AM/FM SELECTOR
14. TUNING
15. VOLUME ON/OFF
16. LANTERN
How do you light a Chinese lantern?
Modern Chinese lanterns made for home decorations are filling the current market. These are available in shops coming in different shapes and colors. The current designs contain strings or cords that are used to supply power and for attaching the indoor home lanterns available. These lanterns use minimal amount of power and are able to use a battery for a long period. Hanging these lanterns on the wall creates a good finished look. The Chinese lanterns are easy to light up using their battery power sources as well as they are permanent objects unlike outdoor lanterns used during festivities and are later released to the skies above.
Aug 24, 2012 | Light Boating
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Jeep Lantern Logo
Top Jeep Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Jeep Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
