Question about Kelty Kenworth W900 Tri-Axle with Trail King Lowboy Trailer
Wiring diagram for trail king trailer - Kelty Kenworth W900 Tri-Axle with Trail King Lowboy Trailer
Why a sudden electrical short in dash lights, park lights and tail lights blows the fuse?
Hi Karen, if you have a trailer hitch check the associated wiring at the hitch.It is common for this wiring to get damaged,also check the trailer wiring.
Mar 19, 2015 | 1984 Nissan King Cab
Need wireing diagram for 05 travel light trailer by r-vision
Disconnect converter. If that stops fuse from blowing replace the converter, it is shorted internally.
Below is the link to the company to get the wiring diagram from.
www.trail-lite.com
Jul 02, 2014 | Optics
2005 suburban , the trailer harness wiring behind the plug in has power for the break and right turn but has no power for riding lights or left turn ?
Find the LEFT INSTRUMENT PANEL FUSE BLOCK. At the TURN SIGNAL/FLASHER MODULE, a 10A fuse (A9?) protects the right trailer stop/turn circuit (DK GRN) which you say is OK. Back at the S/FM, a 10A fuse (A8?) protects the LEFT trailer stop/turn circuit (YEL). At the UNDER HOOD FUSE BLOCK, a 15A TRL PARK fuse (B6?) protects the running/parking lights (BRN).
Sep 04, 2012 | 2005 Chevrolet Suburban
Road king 2008 wiring trailer
Hi Anonymous, for more information on your question please visit the websites below and good luck:
How to Install Harley Trailer Wiring Harness
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 28, 2012 | 2005 Harley Davidson FLHRS - FLHRSI Road...
New trailer wiring for my 06 Nissan Maxima wont work on traile
Have you tried a heavy duty flasher? Also, if your signals & brake lights are 2 different bulbs, as in amber for signals & red for stop, then you will need a small in line converter to separate those 2 as most vehicles use same bulb for signal & stop.
Jun 15, 2009 | 1998 Ford F150 Regular Cab
Want to wire Harley RK for trailer
The wiring for your road king tail/turn lights is: Brown - right turn, Violet/black - left turn, Blue - tail light, Red/yellow - brake, Black - ground to all lights. You should be able to splice into the wiring harness under the seat where the rear lighting plug is located.
Apr 09, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
Wiring diagram or fuse box diagram-2007 GMC Envoy Denali
Hi there;
Here is the wiring diagram for the trailer wiring for your truck.
Hope this helps
Farrout!
Mar 07, 2009 | 2007 GMC Envoy Denali
Tailer running lighs dont work
easy fix.... find the wire that goes to the LICENSE PLATE LIGHT and splice into it and run a new wire to the running light wire for the trail.. it will be very close the the Trail harness
Jan 19, 2009 | 2006 Ford F-150
Kelty Kenworth W900 Tri-Axle with Trail King Lowboy Trailer Logo
91 people viewed this question
Top Kelty Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kelty Toy Expert? Answer questions, earn points and help others
