Question about Boston Acoustics MediaTheater Computer Speakers
Woofer blown need replacement - Boston Acoustics MediaTheater Computer Speakers
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
Jul 28, 2014 | Peavey PR 12 Speaker PA Passive
Hi i have problems with my subwoofer it wont play it's an alpine 12'' type e with alpine mrp m350 amp. there is light on the amp. how do I find out my subwoofer is blown or what else can be...
ok, your amp is in protect mode. either the speaker wires are crossed and shorting out, your woofer's vioce coils are melted and the speaker is blown or the amp is dead.
to determine if the speakers voice coils are melted, and thus the speaker being blown is the reason for the "protect" light, simply push in the cone of the woofer in gently with your hand. the woofer should move a little more than an inch, without any resistance, before bottoming out. if there feels to be any resistance, like a rubbing or scratching, before the woofer bottoms out, then your voice coils are fried, and you need a new woofer.
Nov 25, 2010 | Car Audio & Video
Have Acoustimass 15 system. Subwoofer stopped working and I don't think the fuse is blown. Anyway it does not look blown.
OK - well "look" blown may not be a solid, engineering approved, check. You could take the fuse down to a local Radio Shack and have them test it. Good news is that they will probably have a replacement if you need it. OTHERWISE... Keeping the volume WAY down - you can try another speaker on that output. It doesn't really have to be a woofer, just something to verify the circuit is working. That should tell you if the pathway is good which then tells you if its the woofer or the amp/receiver.
Oct 26, 2010 | Audio Players & Recorders
What is a suitable gale gold woofer replacement?
Really does not matter the point is you can rebuild the woofer for less then replacing with a new one but to each his own on this. But as long as its the same size anything would do for this monitor speaker.
I do not mean to sound generic but its true a woofer is a woofer it is what it is sure there are brands out there but they all work basically the same.
All your doing is buying the name.
Thanks please do click the thumbs above to give me a postive rating for my efforts today,
Feb 13, 2010 | Gale Gold Monitor Speaker
BLOWN WOOFER
there are always good replacement options. just send the woofer size and your budget and choices can be made. you can also have the original reconed.
cathy@spekaerex.com
Jun 10, 2009 | Soundcraft SP820 Main / Stereo Speaker
Need to replace home theater subwoofer-Tivoli TDHT1 is the system
You please check the ohms with the woofer watts so that the same frequency of the woofer you can fix of different company, otherwise there will be damage of the circuit board so please use the appropriate frequency of woofer speakers.
Mar 28, 2009 | Audio Players & Recorders
Blown speaker. Canton as22 blown woofer. Where can I buy a replacement woofer?
 try http://www.parts-express.com they are a really good sourch for speaker replacement . i reccommend using daytons.-z
Feb 24, 2009 | Canton AS22 Subwoofer
Sub woofer amp blown
The output of the transformer goes to a RS404L bridge Rectifier. the 4700uF cap are leaking. Did you work in this area?
Dec 30, 2007 | Audio Players & Recorders
M-Audio StudioPhile DX4 4'' Woofer
The "voice coil" inside the woofer must be rubbing against the "yolk" plate. Meaning = it is mechanically blown(damaged) to a point but electrically intact.
My sugesstion is to take out the damaged woofer and "google" for a mew woofer with the correct impendance and size and mounting holes. If you dont know thw impendance, then you should go with at least 8 ohms. More ohms = less risk of overloading the amp. whick can cause a fire!
Good Luck!!
Oct 20, 2007 | M-Audio StudioPro 4 Main / Stereo Speaker
Boston Acoustics MediaTheater Computer Speakers Logo
46 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
