Question about New Home HF-2022
My new home excel 15S will not reverse and dial above reverse will not move
I have a new home excel 23lL sewing machine and the fabric won't advance
check the position of the forward/ reverse setting
near the middle will not advance the material
take it in for a service
Oct 25, 2016 | New Home Sewing Machines
Reverse does not work on my New Home Janome Excel 23L
it will only reverse in straight stitching if it's not reversing at all,I'd return!
Jan 15, 2014 | Janome D'cor Excel Pro 5124 Mechanical...
Janome sewing machine dial moves
I have exactly the same problem. Did you find a solution? If so I'd be really grateful to hear it ... Thank you.
Oct 23, 2012 | Janome Sewing Machines
Need instruction manuel for a New Home XL 15S
I do not see the manual available online as a PDF. However, you can buy a copy here: http://www.premiersewing.com/new-home-ms3015-xl15s for $13.36.
I hope this helps.
Jun 03, 2011 | New Home Sewing Machines
Where is the indicator to move from one pattern to another on the New Home mx 3123 ? The red light is on behind pattern 1.... How do you move it? Thanks!
it is the big knob on the right hand side below the bigger wheel that moves the needle bar up and down. You have to turn it clockwise to move the indicator to the right all the way to # 13 for straight stitch. It will make a loud click with every move. Make sure the needle is raised up because it jumps back and forth as you move the dial. When you make a buttonhole using pattern 1, when one finishes you turn the dial to #2 then back to #1 to reset the program. I have one right in front of me if you have more questions. This is an AWESOME machine and should never wear out :o)
Jan 15, 2011 | New Home MX-3123 Computerized Sewing...
Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
New Home HF-2022 Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
navapistol
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
