Question about Torin Big Red Torin Aluminum Race Jack with Single Piston Pump - 1 1/2-Ton, Model
How to refill the oil - Torin Big Red Torin Aluminum Race Jack with Single Piston Pump - 1 1/2-Ton, Model
How much oil in a 2012 fat boy low ?
2013 Softail
a. Use 3.5 quarts (3.31 liters) of engine oil for a wet
capacity refill.
b. Use 4.0 quarts (3.79 liters) for a dry capacity refill.
NOTE
Use wet capacity values for engines that have just had
the oil drained. Use dry capacity values for engines that
have been disassembled, cleaned in solvent and dried.
2013 DYNA
a. Use 2.5 qt (2.4 L) of engine oil for a wet capacity refill.
b. Use 3.0 qt (2.7 L) for a dry capacity refill.
2013 Touring
Initially add 3.0 quarts (2.8 liters) of engine oil
2013 VRSC
Oil capacity with filter 5.0 qt 4.7 L
2013 SPORTSTER
Oil tank with filter 2.8 qt 2.6 L 2.8 qt 2.6 L 2.8 qt 2.6 L
Sep 04, 2014 | Motorcycles
Oil pump screen stopped up /98 nissan frontier
I have drained oil refill with gasoline,shake motor,then drain,refill with diesel,shake engine,drain refill with oil.Remove ignition wires,turn engine over till oil pressure rises.Then reconnect wires and run engine.If that does not work remove screen and clean.
Nov 28, 2013 | 2004 Chevrolet Impala
What is the oil capacity of a 1993 Nissan SEV6 D21 pick up? thank you
Refill
oil amount with oil filter change: 4.25 quarts Refill oil amount without oil
filter change: 3.875, depending on engine size as well, this could be up 5ltrs..
Dec 02, 2010 | 1993 Nissan Pickup
Procedure to change manual transmission fluid, 1995 honda accord.
There are two plugs on trany , one drain , one refiil.
Lift car and level it , open refill plug , set aside.
Open Drain plug and drain the oil.
Reinstall drain plug.
Use sifon pump to pump oil in to refill hole.
Fill it up untill oil start coming out of refill hole.
Reinstall refill plug.
You are done.
Plugs are for 22 or 24 mm wrench.One at the bottom the other one at level of drive axle of the transmission.They are same size.
Jun 16, 2010 | 1995 Honda Accord
Vehicle deferential oil change. does it mean transmission oil? or this is something else?
Differential oil change is rear axle oil
Drain and refill
Oil grade SAE 90
Refill 0.9 litres
Mar 28, 2010 | 2003 Toyota RAV4
Ricoh Aficio 2238c: Fuser Oil Unit
It is what it is. No, you can't refill it
Apr 06, 2009 | Ricoh Office Equipment & Supplies
Where do you refill the oil at
Oil heaters are not meant to be refilled. The oil is inside the heater already. If you need to add oil, the heater is defective. Do not use it.
Dec 16, 2008 | Lakewood Oil-Filled Electric Radiator...
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
Ive put petrol in the oil tank
Just drain the oil, refill, and I think I'd run it to warm it up fully AFTER draining and refiling, and drain and refill again. You shouldn't drive it w/ gasoline in the oil, as it will thin out the oil and it won't lubricate as it should, and the extra half litre would be overfilled a bit, which would cause the oil to foam, which also would affect lubrication. countrycurt0
Sep 27, 2008 | 1996 Mitsubishi Eclipse
Torin Big Red Torin Aluminum Race Jack with Single Piston Pump - 1 1/2-Ton, Model Logo
238 people viewed this question
Top Torin Big Red Tools & Hardware - Others Experts
john h
Are you a Torin Big Red Tool and Hardware - Other Expert? Answer questions, earn points and help others
