Question about Xerox WorkCentre 490CX All-In-One InkJet Printer
Aficio color 2003 reset - Xerox WorkCentre 490CX All-In-One InkJet Printer
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Dec 05, 2013 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Aficio mp 6501 with error sc445
. Thermistor is bad, or out of place (check and clean thermistors):(" title="Angry" style="vertical-align: bottom; color: rgb(0, 0, 0); font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 12.4799995422363px; line-height: 17.4720001220703px; background-color: rgb(231, 234, 239);">
2. Fusing lamp is disconnected (check the lamps) :(" title="Angry" style="vertical-align: bottom; color: rgb(0, 0, 0); font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 12.4799995422363px; line-height: 17.4720001220703px; background-color: rgb(231, 234, 239);">
Try to reset this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
For more help visit cbrtechsolutions
Dec 12, 2012 | Ricoh Aficio Mp C6501 Sp
RICOH AFICIO 2232C FUSER THERMISTOR
how do you reset the fuser on a savin clp 27 dn color printer (sc 545 code)
Nov 07, 2011 | Ricoh Aficio 2232C Color Copier
Error sc 452 shown on my aficio 452 color copier how to rectified
sc 452 is a thermistor error code for the fusing unit of the copier. Try pressing these buttons in sequence. (yellow key) (1).(0).(7) (red Clear/stop key) and hold the red key down for 5 seconds. When the 3 or 4 boxs appear, turn your copier on and off with the main power switch. If the error code comes back then contact the seller of your copier and ask for technical service.
Oct 12, 2009 | Ricoh Aficio Colour 3006 Color Copier
Ricoh sc 551
This is a fuser temp. problem -- must reset and/ or replace thermistors.
Press clear modes button then 1-0-7 then hold down the clear stop button.
When display changes touch copy sp modes.
Turn may power off and wait about 30 sec.
Turn power on.
If the machine comes to ready you are ok for now.
If code returns you must replace thermistors.
If you need to replace thermistors, contact me and I will get you part numbers and instructions.
Jan 15, 2009 | Office Equipment & Supplies
Ricoh aficio color 2003
related to the scanner
there is a white strip on the scanner glass , either that is dirty or the mirrors(optics) are dirty .
or scanner ipu board
Ricoh color copier service code
Hello sir; Let's try to reset;
1, press "clear mode", "107", then press and hold down "clear/stop" for about 3 second.
2, touch copier SP,
3, enter SP5-810-2 pres enter.
4, press 1, then turn power off and back on .
Jan 15, 2009 | Ricoh FT3713 Copier
Xerox WorkCentre 490CX All-In-One InkJet Printer Logo
14 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
