253.54669405 model kenmore frig side by side water/ice in left door.
how do i remove the face plate, and the unit holding the water/ice dispenser so I can replace the water dispenser paddle which has broken at is neck?
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Kenmore 54662 / 54664 / 54669
Kenmore 54662 / 54664 / 54669 Side by Side Refrigerator
I am trying to resolve no water coming from the door dispenser. I have ice. I cannot locate the...
(More)
I am trying to resolve no water coming from the door dispenser. I have ice. I cannot locate the reservoir. I pulled out the crispers and I did not see a reservoir. Please help. Thank you.
I can change between cubes and crush (indicator light switches between the two), but regardless of...
(More)
I can change between cubes and crush (indicator light switches between the two), but regardless of the setting it only gives out crushed ice. Not sure if it is electrical, but after taking the faceplate off, it appears to all be electrical. Please help.
on the 54669 kenmore frig, how do I remove the ice/water dispenser after i take off the faceplate on...
(More)
on the 54669 kenmore frig, how do I remove the ice/water dispenser after i take off the faceplate on this side by side indoor dispenser?
