Question about LG Front Load Washer And Dryer Wm2250cw Dle2250w
Lg washer and dryer WM2250CW / DLE2250W WARRANTY problems
Lg wle1501w dryer no power
Since its brand new it should have a warranty I would use that since you trying to could void that.
Jul 05, 2017 | LG Dryers
LG WM2250CW has a drip underneath, front and center. Used, but new to us. Help!
Before doing anything else, check and see how dirty the glass window is along the inner edge where it contacts the gray seal. You will find that the very bottom of the glass is all gunked up with detergent , hair, lint, etc. Clean all around it using a scotcbite pad and water. These seals will leak if the glass is dirty.
Jun 02, 2015 | LG Washing Machines
The Dryer Does not get hot . On the panel it says Cooling
Start simple. Turn breaker all the way to off then back on a weak breaker can flip internally and only give half voltage. Try ...if that doesn't work take top and front off check heating element and thermostats with a volt meter ohm each out with wires off. be sure to turn power off first 240 volts hurts
May 08, 2015 | LG DLE2250W Electric Dryers
Dark streaks after washing
This has been a problem with LG front loading washers for quit a while, unless its in warranty I would not spend the money for repairs . Buy a good basic model heavy duty top loading washer for around $500.
Sep 15, 2013 | LG WM2233H Front Load Stacked Washer /...
LG Front load Washer WM2250CW, on the front ,bottom, left, there is a small, looks like a small door,6"X6". What is it and whats it for, and does it open
It is an access point to get to the drain pump. There is usually a plug which can be twisted off to get to any blockages by the pump filter. Caution when opening the plug because there is always water on there.
Aug 31, 2013 | Washing Machines
Front Load Washer
Call LG customer service and tell them your problem.  1 800 243 0000.
Jul 14, 2008 | LG WM1812C Front Load Washer
Dryer
i used to do warranty work for LG needless to say, after finding out customers were waiting up to 2 1/2 months just to get parts i stopped doing any work for them. if it were me, i would take both the washer and dryer back and buy a bosch instead. much more reliable and there customer service is great
Nov 28, 2007 | Dryers
Which front loader do you recommend?
You have to consult "dovi" on this site.........
Nov 11, 2007 | LG WM1814CW Front Load Washer
LG Front Load Washer And Dryer Wm2250cw Dle2250w Logo
53 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
