Question about Kenneth Cole KC1346 Watch for Men
Removing the back of a kenneth cole KC1346 watch to replace battery
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: how do I remove link in kenneth cole new york
Check my tips and tricks. Watch band is called bracelet as well.
Posted on Jan 23, 2010
escapement
  • 2334 Answers
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Posted on Feb 28, 2010
SOURCE: how to replace the battery in a kenneth cole watch kc3346
I have not figured out how to open the casing lid to replace the battery, but the number for the battery you need should be engraved on the lid. Double check your own lid, but mine says that the battery is an SR621SW. I'm sure there are different brands that would match this number.
Posted on Aug 04, 2010
Battery size for Kenneth Cole KC3679 watch
Take your Kenneth Cole watch to a jeweler who will open it, identify the battery type, and perhaps install a replacement.
Apr 17, 2017 | Kenneth Cole Watches
How do I take the back off of a Kenneth Cole watch kc1346
Could use butter knife or similar something to pry up case back , there is back of watch 12 O'clock side between case and case back put butter knife in and pry up . Be careful make sure not hurting yourself and same time be gentle make sure not damaging something
Jan 25, 2016 | Kenneth Cole Watches
Which replacement battery for kenneth cole kc3565
Remove back of watch small pearing knife will do careful silde under back to remove battery
Aug 05, 2014 | Kenneth Cole Mens NY 3 Eye KC3565 Gunmetal...
Manual kenneth cole for watch ul 1181 where can i get the manual
i am not understanding ......
you need Manuel for replacing battery ?
or
you need Manuel for setting up digital part of your watch ?
Jul 28, 2014 | Kenneth Cole Unlisted Chronograph Watch
Replacing the back on a KC3556 kenneth cole wrist watch
I suggest you contact the maker by going to their web site http://www.genevawatchgroup.com/ (this is the maker) and speaking to them. You are not the first to have this kind of problem and they should be able to sort it out for you.
Jul 15, 2010 | Kenneth Cole Watches
Watch battery size
mcdevito75 here, Best Bet For correct Battery Number is to call Kenneth Cole T 1-800-KenCole / 536-2653
Jul 01, 2010 | Kenneth Cole KC1346 Watch for Men
Have a Kenneth Cole watch and the battery needs replacing. The watch is a KC1239. Any solutions?
Get a flathead screwdriver from eyeglass kit and the back cover will pry off to replace battery
Jun 27, 2009 | Kenneth Cole KC1239 Wrist Watch
Losing TIme and Stopping completely!
i think you may need to change the battery!
Feb 16, 2009 | Kenneth Cole KC1346 Watch for Men
CRACKED CRYSTAL
Hey man all you have to do is mail the watch to Guess, their service dept is world class. I found a lost guess watch behind a car seat. It was lost for 10 yrs i mailed it in, the fixed it to mint condition and charged me $13. I took another guess watch to the mall to have the battery and crystal replace, dont take it to Mohammed just send it back to guess, they will fix anything they find wrong and mail it back to you. I have dont this twice and they dont rape you in charges, they were way cheaper than those loosers at the watch shop.
Feb 03, 2009 | Kenneth Cole Watches
Kenneth Cole KC1346 Watch for Men Logo
42 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
