Question about Largan Chameleon XP Digital Camera
When i install my camera, the function of webcam doesnt work
Someone lend me the camera & he used it without installing in webcam mode & i download the program for installing the camera because my pc didnt recongnized it, & then it works & i can download the pics but not using like webcam, What can i do :S?
  • Anonymous Nov 25, 2007
    where I can download the software of my largan chameleon slim for free
  • rinkusingh Dec 03, 2007
    i have no software to open the camera.
  • 259 Answers
Here are the latest drivers. See if this helps. Here are the driversWhen i install my camera, the function of webcam d - 2.gif to your camera:
http://www.largan.com.tw/digital/download_en.htm
Posted on Dec 15, 2007
SOURCE:
No webcam detected. If you are using an integrated camera, make sure that it is turned on
You are using a device which works only with Win-Seven OS or higher. I've got the same problem with my optical mouse (without cable) .... Try to re-install your camera's driver in your pc... if this doesn't works... try to install your camera in a PC or Laptop with Win-Seven OS
#NZ
Nov 10, 2013 | Averatec Computers & Internet
Hey uNinstall and reinstall the it and the Fn+Ecs still does'nt work.. what will iDo? can someone please help me.. iAm using lenovo Y310.. thanks
Try using ManyCam as your camer's software.
You can always download Manycam and install it. Go to www.google.com and in the search box type: "download.cnet.com" (without the quotes). Click on the link to go to the site. When the site opens look down on the left and you will see a gray area that says Find Software. Type "Manycam" (without the quotes) in the white search area then hit the search mirror. When it brings back your results look for the one that says ManyCam Virtual Webcam. Down load it and install it. Make sure you remove the check box on any junky programs it would like to install. You only want to install ManyCam, no additions whatsoever during the install. ManyCam is totally FREE and easy to use, and you will always know where your webcam software is.
Once you have it installed and working you can visit ManyCam's website to get instructions on how to use it with other applications such as facebook, etc.
May 22, 2012 | Computers & Internet
'No driver found' for my Logitech QuickCam Chat? Ok, I have the basic QuickCam Chat Camera. It looks like this: http://pics.unitedsale.info/img001/Logit? When I install the camera, it says that it did not...
A driver is a computer program used to run a device or hardware.
You can download the Logitech software bundle from here
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Browse the photo gallery and click on your pic to move to the support page for your model
Click the 'download' link to what OS Logitech support for your cam
Older webcams will not have a windows 7 driver but you may be able to download the bundle and run it in Compatibility Mode
If no driver is available try using the older OS software in Compatibility Mode
Right click on the webcam icon on your desktop or the webcam file from 'All Programs' - select 'Properties'
Select the 'Compatibility' tab
Select 'Compatibility Mode'
Use the dropbox to show the OS
Click OK
Restart your computer
Jun 23, 2010 | Logitech QuickCam® Chat Web Cam
How to install web camera (logotech 5.4.1) without CD
Depending on which operating system you are running, it is possible to install without the CD. Generally Windows Vista and Windows 7 are plug and play, which means you can plug the camera in and Windows will apply a generic driver to it, making it functional but not as functional as if you had installed with the disk. Example, you would not be able to use the camera software as it would not be installed. Check the manufacturer's website and see if there is a newer software for you version of Windows. You can download it free. The site will also tell you if the camera is compatible with your current operating system, which, unfortunately, many are not with Windows 7.
Apr 02, 2010 | Logitech Webcam
My webcam wont work on msn
double check your msn settings to see if its configured to use your webcam as its webcam device. try running the phillips software first and see if the webcam is actually functioning and verify that its installed properly...you can also just try a simple re-install of the camer and see if that works. soemthing silly...see if the camera has an on/off button (they usually do for privacy to turn it off immediately and it doesnt neccessarily say "on/off".
Apr 26, 2009 | Philips SPC611NC Webcam
Webcam working on macam but not skype
Maccam comes with a file called maccam.component. You must copy that file to /Libraries/Quicktime which is on your main hard disk. This enables the camera to function with quicktime and other software on the Mac besides Maccam.
Read about it here:
http://www.von-phone.com/macam-skype-webcam.php
It worked for me. Best of luck.
Apr 02, 2009 | Logitech QuickCam Pro 9000 Web Cam
It doesnt open the webcam
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Dec 30, 2008 | Logitech QuickCam Messenger Web Camera
Lost my webcam installation cd
can someone help me? I lost my CD installation too...
May 25, 2008 | Logitech QuickCam Express Web Camera
Install A4 tech PK635 M web cam without cd installer
Just plug the webcam in and windows will automatically install the drivers, if it asks for the drivers just insert the disc, when you do this windows will auto play the CD so just shut down the auto install program and leave the disc in the drive and carry on with the driver installation manually.
Here is the driver download as well: http://www.a4tech.com/ennew/download%20driver.asp
Cheers
May 18, 2008 | A4tech Xmaster PK-835 Webcam
Driver for Veo Connect Personal Web Camera
i lost the drivers cd for my web cam, veo 640vs24x
Jul 23, 2007 | Veo Connect Webcam
Largan Chameleon XP Digital Camera Logo
73 people viewed this question
Top Largan Cameras Experts
Ekse
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Are you a Largan Camera Expert? Answer questions, earn points and help others
